Go to Post Throw the programmers (or freshmen with duct tape depending on the state of your robot) in the trailer with the robot for the ride between events. Problem solved. :D - ASD20 [more]
Unread 10-12-2008, 10:56
Delian Delian is offline
FRC #3006
Delian is on a distinguished road
Help to Deploy a Program in Labview.
My laptop can find the cRIO controller through the imaging tool, yet if I try to deploy or run any program, it tries to establish a connection, and then quits out. My IP address is the correct one for our team (Team 3006: 10.30.06.6). I have also tried deploying sample code and this does not work either, I am running on Labview. Does anyone have any idea how to solve this?
Unread 10-12-2008, 11:14
Re: Help to Deploy a Program in Labview.
Is the cRIO IP address shown for the cRIO in the FRC cRIO Imaging Tool correct as well?
(10.30.06.2)
Any Firewall running?
Unread 10-12-2008, 11:17
On a side note, does the imaging tool just assume a 10.XX.YY.2 IP address for the cRIO, or does it use Bonjour type service?
I'm assuming its the latter since there is no guarantee your laptops IP scheme (team number) matches the cRIO.
Unread 10-12-2008, 11:57
Hard to tell. It seems to scan the subnet plus 0.0.0.0
Unread 10-12-2008, 16:04
FRC #3006
No, it shows the correct IP, address, I believe I found the problem though, somewhere in the forums i read that there is a thumbwheel which you have to spin in the correct orientation to make it accept programs. If anyone knows where this wheel is, that would be very helpful.
Unread 10-12-2008, 16:16
I haven't heard that one before...
Unread 10-12-2008, 16:27
qnetjoe qnetjoe is offline
AKA: Joe Daily
qnetjoe is on a distinguished road
Send a message via AIM to qnetjoe Send a message via MSN to qnetjoe Send a message via Yahoo to qnetjoe
Delian,
First just to make sure that everything is set up right ping the IP of the cRIO. If that does not work then double check your network settings.
Assuming that you can ping the cRIO then in the project explorer you should see an entry labeled RT CompactRIO Target (IP of cRIO). If you right click on that entry then click on connect. If everything connects properly with no errors all you have to do is open Robot Main.vi under the RT CompactRIO Target entry and then click on the run icon (the little arrow in the upper left most toolbar).
Thats it!
if you have any issues please feel free to PM me.
Unread 10-12-2008, 21:13
FRC #3006
So when I create a project, I should run it from the Robot Main, not the individual program itself?
Tip if you ever want to program network applications in LabVIEW Michael Hill National Instruments LabVIEW and Data Acquisition 1 24-10-2008 20:31
97's Ramp Deploy ZZII 527 Robot Showcase 5 28-02-2007 15:18
Team 1345's ramp deploy and robot on top. Arefin Bari Robot Showcase 7 07-02-2007 17:17
NI LabVIEW and Data Acquisition Pilot Program 2006 Application Ready! Danny Diaz National Instruments LabVIEW and Data Acquisition 2 18-10-2006 15:55
help: cannot get the picture in the labVIEW program .. (was: need help!! quickly!) liad LabView and Data Acquisition 8 18-01-2006 12:20
