Go to Post When you open of CD and you see your very own quote up top, and can't decide if it's a really awesome or "Well...this is awkward..." moment - CalTran [more]
Unread 09-12-2008, 17:30
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
Camera
How do you wire the power for the new camera? Thanks!
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 09-12-2008, 17:43
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Camera
Look here.
Unread 09-12-2008, 18:20
darkember darkember is offline
AKA: Billy
FRC #0375 (Robotic Plague)
darkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of light
Re: Camera
You have to cut the transformer off and connect the wires to the power distribution board at the 5v power supply.
Unread 09-12-2008, 18:27
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
Re: Camera
See:
http://www.usfirst.org/community/frc....aspx?id=10934
Chapter 3 section 3.2.6
How do I build a cable for passing 5V power to the Ethernet camera?
You received 2 camera power supplies, make sure that you cut up the right one.
Unread 10-12-2008, 11:05
Zflash's Avatar
Zflash Zflash is offline
AKA: Erich Zende
FRC #1319 (Flash)
Zflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud of
Re: Camera
Do not cut the one that came with the camera. The extra one that you recieve is the one to cut.
Peachtree '08 Champion Thanks 343 & 547
Galileo '07 Champion Thanks 173 & 1902
Palmetto '07 Champion Thanks 832 & 342
Boilermaker '06 Champion Thanks 1272 & 85
Unread 10-12-2008, 15:55
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
Re: Camera
I'm pretty sure i used the one that had came seperate in the red bag, but just checking, would it make a difference if you had used the other cable?...i would think that it wouldnt make a difference.
Unread 10-12-2008, 16:05
Re: Camera
One of the cables has two separate wires running side by side, the other is coaxial. Using the coaxial cable is a pain in the rear end, but otherwise completely doable.
Unread 10-12-2008, 16:07
AKA: Randy
Re: Camera
The one that comes in the separate bag has much a much lower current output rating. At some point you may want to use the camera off of the robot. It would probably be better to use the power supply that came in the camera box for that application.
Check the part number from the link in my post above.
Unread 12-12-2008, 08:31
Re: Camera
Personally, I am opposed to breaking something that is already working.
2009 FRC Control System Manual: Section 3 – Component Datasheets, Rev 0.5
"How do I build a cable for passing 5V power to the Ethernet camera?
• Take the camera’s power adapter (PN SA106A-0512-6) and cut the wire off close to the
Wall-Wart.
o Note: There are two power adapters for the camera included in the Kit, one in the
camera box and one separate. Use the separate one (PN SA106A-0512-6) to make
this adapter.
• Separate the wires and strip 5-6mm off the ends.
• Use a small flat head screwdriver to open the WAGO 739-302.
• Insert the positive (striped) wire in the right port. Note: the correct orientation can be verified
by looking at the silk screen on the PD Module.
• Insert the negative wire in the left port.
• Give a smart tug to verify the connection is secure.
• Power the PD, and verify that the barrel connector’s center conductor is positive."
I bet if you take the power adapter to Radio Shack(Digikey, Mouser, etc.), you will find a connector that you can wire yourself.
Unread 12-12-2008, 13:30
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Re: Camera
These are the parts that we used to do this, from RadioShack:
http://www.radioshack.com/product/in...ductId=2103612
http://www.radioshack.com/product/in...ductId=2102487
Look for a "DC Power Plug", sizes "H" and "K". I forget which size is which, but we used one for the camera and one for the wireless bridge.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Tell the difference: 2007 CMU Camera, 2006, 2005 camera? Chris_Elston Programming 2 07-01-2008 13:11
CAMERA Slick Programming 30 10-02-2007 13:30
Camera The yellowdart General Forum 4 21-01-2007 22:56
Camera Help (New to Camera Programming) Idaman323 Programming 6 14-01-2006 03:56
Camera Malfunctions Alex698 Programming 1 04-02-2005 18:32
