Go to Post I was thinking (dangerous I know) - EricH [more]
Unread 10-12-2008, 15:50
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
Re: pic: "You should never go against a robotics kid"
...3 kids from 1501 (non-school sponsored team) were finally allowed to be in a group together in our schools engineering class. It was the first time the teacher let us choose our own groups. It was 1 mechanical, 1 electrical (me), and 1 design student. The task was to demonstrate a usage of pneumatics. We could recreate something using paper, or any other building material. So while most kids used the manual valves, Our group was the first in the classes history to actually use the solenoids in the kit. We did not have a programmer, but i managed to figure it out in a couple of minutes...
Anyways, while most people made something simple like the outriggers on a bulldozer, our group made a pneumatic claw! It was massive compared to all the other projects, used more solenoids than our last 3 bots combined...and used 2 controllers because the schools could only handle 4 motors/solenoids a piece. It could pinch. move outward/inward, and tilt up and down. I will try to remember to snap a pic of it tomorrow... If you can see it lol, its made out of awesome clear plexiglass
Unread 10-12-2008, 16:47
dtengineering's Avatar
AKA: Jason Brett
Technically the lack of a counterweight does not disqualify this as being a trebuchet... rather it puts it in to the category of the traction trebuchet. http://members.iinet.net.au/~rmine/htt/htt02.html
Jason
Unread 10-12-2008, 17:26
ComradeNikolai ComradeNikolai is offline
AKA: Nicholas
FRC #2603 (Team Hornet)
ComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to behold
First, however we define what this creation is, it is wickedly cool. I wish I had a class like the one you built that in... and team members to build it with.
Originally Posted by martin417 View Post
OK if we go with the Webster definition of catapult "an ancient military device for hurling missiles", then yes all trebuchets are catapults (but obviously not all catapults are trebuchets). That would then mean that all missile throwers are catapults, including ballistae, onangers, mangonels, and even more modern weapons like howitzers, cannons, rifles, pistols, magnetic rail guns, FA/18 jet fighter...... All of these devices hurl missiiles. (though not all could be classified as ancient).
But if we look at Webster's definition of Trebuchet "a medieval military engine for hurling heavy missiles (as rocks)" there is little difference. It would appear as though the two devices are the same. I attribute this discrepancy to laziness on the part of Webster. I still think a catapult refers to the traditional definition of on arm with a basket on the end that rotates about a pivot until it hits a stop, thereby propelling a projectile forward.
I believe these definitions are far too vague to get a good definition (just as I would never define "justice" by a Webster definition; it's good for a quick reference, but for anything remotely technical, it is lacking). For the sake of rapid research, I'm going to use Wikipedia's definitions:
Catapult is defined as "any one of a number of non-handheld mechanical devices used to throw a projectile a great distance without the aid of an explosive substance;" this invalidates the examples of Howitzers and does include ballistae; originally, catapults referred to "ballistae" and ballistae referred to "catapults;" the definitions switched, but it can apply to either as long as it does not use explosives.
This is an example of a catapult.
Trebuchet includes the following: "trebuchet is often confused with the earlier and less powerful torsion engines. The main difference is that a torsion engine [ie mangonel or ballista] uses a twisted rope or twine to provide power, whereas a trebuchet uses a counterweight" and it continues to state "A trebuchet also has a sling holding the projectile, and a means for releasing it at the right moment for maximum range." and "Both trebuchets and torsion engines are classified under the generic term 'catapult,'."
This would appear to be a torsion engine, or a "torsion trebuchet;" however, that is not the normal context of the term "trebuchet."
I would argue that this is a torsion engine but not a trebuchet, for a trebuchet uses a counterweight, whereas the surgical tubing more closely matches the twisted rope used to power many catapults, such as mangonels and onagers.
I apologize for the length of this post, but I love both debate and medieval weaponry... This is not a confrontational post, it is just my viewpoint on it.
I cut myself shaving with Occam's razor.
Unread 10-12-2008, 17:34
ATannahill ATannahill is online now
AKA: Alex Tannahill
You're fighting over whether this is a catapult or a trebuchet? I feel you time and effort is being used as well as if it went towards the game hint.
- Arizona North
Unread 10-12-2008, 17:45
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Game hint? you mean the picture of a fish? The one that has a topic with over 700 posts discussing a picture of a fish? what else can be said about a picture of a fish that hasn't already been said? This catpult / traction trebuchet is a whole lot cooler, and is much more interesting.
Former Mentor Team 1771
Former mentor Team 4509
Unread 10-12-2008, 17:51
AKA: Samir Shaikh
FRC #4329
the trebuchet is probably also more relevant to the game then the fish also
Unread 10-12-2008, 18:09
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It's a trebuchet with a twist
Unread 10-12-2008, 18:17
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
A torsion engine stores energy through torsion or twisting of something (usually ropes). The catapult pictured stores energy through the stretching of the surgical tubing, not twisting.
Unread 10-12-2008, 18:21
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
Originally Posted by Barry Bonzack View Post
I would suggest to the administration to simply change the projectile. Tennis balls, oranges, and racquetballs are a bit softer. How many projects do schools offer that teaches THIS much and is also fun to do?
I agree Barry! I think, however, before the decision is made extensive testing is needed. I propose setting up a "splatter wall" and flinging all kinds of fruits at it to see which one makes the prettiest pattern. (oh yeah, and safest).
Dave, can you spare a banana or two?
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 10-12-2008, 18:36
Catapult/trebuchet/launcher throws the fish across how far???
Hey, could you guys find an opah and launch it, just to relieve everyone's stress around here (and discussion of the game hint)?
Unread 10-12-2008, 18:58
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
how did you make it realease on end of the sling at the right time? or was it just try-bend?
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 10-12-2008, 20:02
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
If you look closely at the picture on the right (the CAD does not have it) there is a piece of 1/4" aluminum coplanar to the main arm that has a slight V shape cut out. The release angle wasn't perfect (was about 35 degrees I think) but it was good enough. And since it was luck that it went at that angle on the first try, the group decided to just keep it that way.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 10-12-2008, 20:04
AKA: Jason Brett
First of all, I don't think anyone is "fighting" over anything. There is a polite, rational discussion going on as to the appropriate terminology to use when referring to this design. Precision with words is equally as important as precision in drawings, or in machining. Often it is more important!
But I do appreciate the humour in the statement.
Jason
Unread 10-12-2008, 20:12
The Blue Alliance
I think we decided to call it a "Catachet"
Sounds French...
Eugene Fang
Unread 10-12-2008, 21:23
AKA: Nicholas
Sounds French...
Or a "CAD-achet."
pic: things never workout the way you want them to. shotgunking777 Extra Discussion 13 19-01-2005 07:57
[TSD]: Midnight Mechanics (Team 812) compete against UCSD students in robotics preussrobotics FIRST-related Organizations 1 25-12-2004 15:27
pic: Never seen of! Never heard of! The secret revealed! CD47-Bot Robot Showcase 5 06-03-2003 15:49
Do you have something against texas?!?! tenfour Chit-Chat 5 12-12-2002 21:38
Where Are you Beanie Kid?????????? Little Lee132 Regional Competitions 3 10-04-2002 17:42
