#16
Re: pic: West Coast Drive: Spokane Style
just to clarify a little more for you akash... If you look at pics of our bot last year that is a good example of non-cantilevered....254/968 are a good example of cantilevered |
#18
I don't think you will climb anything over 20 degr. with bumpers mounts in front of the wheels.
#19
EDIT: I never sleep.... I need to stop forum lurking.... Last edited by CraigHickman : 10-12-2008 at 09:52. |
#20
ok, so I've been looking at these West Coast drives forever, but I still can't figure out where the bearing blocks for the wheels come from. Are they an off the shelf part you can get from mcmaster by any chance? My team has no milling whatsoever so I'm stuck with finding parts from a store.
#21
In all of the west coast designs I know of and all of the ones I have designed, the bearing blocks are custom machined parts. There really aren't any good off the shelf parts that I know of to accomplish this. You could always look around for a machine shop to donate some machine time. Many shops are very receptive to robotics stuff. You could also use some of the bearing blocks from team 221 although I don't know if they would work for what you want to do.
#22
I am not advising either way with these. There are many more options like these, but it might get you headed in the right direction. A pair of these per axle should do the trick. |
#23
![]() Last edited by s_forbes : 10-12-2008 at 18:32. |
#24
I'd suggest looking into using the KOP frame (it really is awesome) if you have no resources, or try finding some resources. Opening a phonebook/google maps and calling machine shops will surprise you with the results. You'll see that there are both more local shops than you probably think, and more are more willing to help than you probably think. |
#25
Adam's right. I just did a quick Google Maps search for "machine shops Kansas City" (noting your location) and came up with quite a few.
#26
Looks good.
Is there any reason that you have the frame extending in front of the front and back wheels? I know that in the past, one reason for this part has been so that when you ram something, you can't hit it with your wheels. But we now have bumpers, so that isn't necessary. And by removing it, you can move your front wheels up 1 inch, making it easier to climb stuff. |
#27
They weren't allowed last year. It had to be a bolt system.
| "West Coast" drive? | pogenwurst | Technical Discussion | 32 | 17-12-2008 19:50 |
| pic: West Coast SS mounting 3 | AdamHeard | Extra Discussion | 2 | 17-06-2008 13:11 |
| pic: West Coast Altered | Alex.Norton | Extra Discussion | 25 | 13-06-2008 00:13 |
| pic: West Coast Collaborationz and Team 254 Present | phrozen solyd | Robot Showcase | 22 | 28-02-2005 01:31 |
| East Coast, West Coast, and Midwest FIRST | Aaron Lussier | General Forum | 52 | 04-08-2003 01:52 |
