Go to Post I'm basically only posting this so that future Shaker Robotics kids will see it and tell themselves "never again"... - Chris is me [more]
Unread 10-12-2008, 18:32
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: cRIO test drive *OFB* problem....
It takes a while for the DS and cRIO to fully start up and sync after powering up, but if you're tethered it shouldn't take more than a minute.
After that, when you enable the robot, the system should respond almost immediately (+- a few secs).
If you're not getting a response from jags, try using servos in their place (don't forget the jumper!).
cRIO plugin problem gabrielse National Instruments LabVIEW and Data Acquisition 3 18-12-2008 11:30
[FTC]: 35's Drive problem wilsonmw04 FIRST Tech Challenge 30 15-12-2008 07:28
Mystery problem: exponential drive ida_noeman Programming 9 21-01-2007 12:39
TechnoKats Automated Test Drive Code Greg McCoy Programming 1 16-01-2003 17:45
