Go to Post I dont think it matters too much what you do, as long as you do something that lets you apply what you're learning in class. - MrForbes [more]
Unread 23-06-2002, 23:47
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: single acting valves -- FIRST, you're scaring me...
Posted by Gary Bonner at 1/30/2001 12:10 PM EST
Other on team #433, MINT, from Mount Saint Joseph Academy and Pew Foundation.
In Reply to: Re: single acting valves -- FIRST, you're scaring me...
Posted by ChrisH on 1/29/2001 5:09 PM EST:
: You are right to be concerned. However there is a solution right in the box with the other pnuematic stuff. It's called a pilot operated check valve. Used properly it will cause a single solenoid valve to act like a double.
With what do you operate the pilot? The other single valve? The list of valves is pretty short to start with. And there’s only one pilot operated check valve in the kit.
The assortment of components in the pneumatics kit is tempting, but the limited number of valves severely constrains what you can do. To justify adding the weight of the compressor, tanks, etc. to your robot, it would be nice if you could do more than one or two things with it.
[IMG] code is Off
solenoids from last year Antonio Pneumatics 6 29-01-2003 22:59
solenoids hot69z Electrical 2 08-01-2003 06:02
Rookie Question. double solenoids... archiver 2001 2 24-06-2002 00:57
solenoids zarb Electrical 1 28-01-2002 23:19
solenoids rdmendola Electrical 1 26-01-2002 16:58
