Go to Post Every match they would leave blue and red skid marks all over the carpet. It was like someone roadkilled a Smurf. - Koko Ed [more]
Unread 10-12-2008, 21:29
Alex Dinsmoor's Avatar
Alex Dinsmoor Alex Dinsmoor is offline
Are our seeding points over 9000?
FRC #0201 (FEDS)
Alex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant future
Send a message via AIM to Alex Dinsmoor
Re: Problems with Victor 884
Originally Posted by Don Rotolo View Post
We completed out Out of The Box test last night, with one Jaguar and one Victor connected - both worked fine (with the effects Joe noted) with no changes to the OTB code.
Did you use the new Victor that came with the kit, or an older one from a previous year?
Alex,
Normally I suggest that speed controllers be mounted near the motors they are controlling to minimize the wire runs. There is nothing in the picture to prevent you from using perf stock or a piece of lexan on the uprights across the back of the robot. Then you can mount the controllers vertically on that. Since the Jaguars have mounting holes in the sides, you can use threaded standoffs to elevate every other one and using the standoffs, rotate the elevated controllers 90 degrees to allow you to stagger them and fit more in the space. That way, no fans are occluded and the wiring is spaced out. Also, mounting the controllers so that they are front to back rather than side to side, works well too. This allows them to be mounted next to each other and touching. The wiring works better that way as well and the only drawback is getting the PWM cables attached. In your actual robot, don't forget to mark your wires and controllers. You can get 3M wirk marking tape from Digikey. It is expensive (about $30 for a dispenser with all 10 EIA colors) but is well worth it when you are trouble shooting.
All of these are really good ideas, I will be sure to pass these along to my mentor! I'm glad we used zip ties to attach all of the components of our electrical board, now no one can make to big of a fuss if we decide to rearrange the board.
'08, '09, '10
4 Years | 14 Competitions | 194 Matches | 119 Wins | 77 Losses | 2 Silver | 1 Gold
Problems with victor blowing JamesBrown Electrical 18 17-02-2008 20:36
Victor 884 Problems Team 135 Electrical 12 05-02-2008 13:24
Victor 884 Devo1098 Electrical 6 29-06-2007 07:51
Victor 884 Kevin Ray General Forum 25 28-01-2003 15:02
Victor 884 Gary Bonner Technical Discussion 4 14-01-2002 08:10
