Go to Post To think that one can "learn" engineering in 6 weeks while under the strain of building a robot too is proposterous. FIRST isn't about teaching. It's about inspiring. - Collin Fultz [more]
Unread 10-12-2008, 22:09
waitwhat?'s Avatar
waitwhat? waitwhat? is offline
Driver Coach
AKA: Bunca
FRC #0747 (Flight Crew)
waitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant future
Team 869 In Need of Some Advice
Hey guys, so here's the story. Our machine shop from prior years is not going to be able to help us this year with our robot. Although our team is hard at work trying to find a replacement shop, the possibility of not having a shop this year is growing bigger and bigger. I am just wondering if any of you guys would have any good bits of advice as to certain design tips. Basically any advice that would help out a team whom does not have a metal shop at their highschool, and only has access to hand tools, some power tools, as well as a bandsaw and drill press, both capable pf cutting wood and aluminum. Also, any materials that are easy to modify with such tools, but do not require cnc milling to become usful. Sorry about the poor grammer but everyone is starting to panic a bit. Hopefully someone out there can point us in the right direction. Any input would be greatly appreciated!
Unread 10-12-2008, 22:13
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
Re: Team 869 In Need of Some Advice
Is there a reason on why you can't use the machine shop from prior years?
I guess ask around at small or big local busnesses that manufacture stuff, that could be a possibility, but it sounds like you have already tried that.
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 10-12-2008, 22:18
MikeMascaro's Avatar
MikeMascaro MikeMascaro is offline
Fearless Leader
FRC #0888 (Robotiators)
Team Role: Driver
MikeMascaro is an unknown quantity at this point
We've built a robot without a real machine shop for all eight years so far. We just use drill press, etc. It's not too bad, you just make sure you have enough time allotted to actually build your robot, because I imaging having a machine shop is faster then not having one. We normally build ours in around two weeks, with the other four weeks for prototypes.
The man with the red hat. Hopefully I'll see you!
Unread 10-12-2008, 22:21
alex1699's Avatar
alex1699 alex1699 is offline
ummmm thats meee......
FRC #1699 (robocats)
alex1699 has a spectacular aura aboutalex1699 has a spectacular aura aboutalex1699 has a spectacular aura about
Send a message via AIM to alex1699
umm well find a two car grudge and use what you got its what team 1699 did for the last few year!
and it gets the job done!
but for materials rivits nuts and bolts the basics...
for welding try some of your naboring schools that might be willing to lend a hand. you just might get them in to first!
umm... what else i think we got a lot out of working in the gruage. learning more respect using are tools and such. you might not have all the mills and such but i found it good cuase you got to look out side the box in making make shift ways in doing things.
good luck on find a place to work!
Curie..
Unread 10-12-2008, 22:32
joshy1323 joshy1323 is offline
AKA: josh anderson
FRC #1323 (madtown robotics)
joshy1323 will become famous soon enoughjoshy1323 will become famous soon enough
i am very sorry to hear that. unfortunately you are located very far away from my team so it would be difficult for us to give you any physical help. and i do not know what my team would do if our tools were taken from us. but keep hope because plenty of teams build good robots with very limited resousces. my team started without a machine shop of any kind and we still built competitave robots in the beginning. one thing that helped us was generous buisnesses with machine shops in our town. people are usually happy to help once they have heard about the things FIRST does. i wish i could help more and if there is anything my team can do to help you out from this distance do not be afraid to ask because we will do all we can. good luck
and to any teams that may have a problem similar to this in the central california area please dont be afraid to ask for help. we have plenty of machining capability and we would hate to see a team fall from the competition if there was something we could have done to help.
----1323 josh
Unread 10-12-2008, 22:39
Billfred's Avatar
Billfred Billfred is offline
You've more or less described 1618's shop. Of note:
-There is no shame in using the kitbot. Get it together, make whatever cheap improvements you can (for us, that was going 6WD, riveting the frame, and adding AM Super Shifters), and focus on your manipulator.
-Think simple materials. We built the main arm for our 2007 robot, Uppercut, with a few pieces of angle aluminum and one length of PVC pipe from the local hardware store. Bolt it all together, put a window motor (or its equivalent for 2009) and you've got a single-stage arm. Now focus on a manipulator.
-Focus what machining resources you might be able to scrounge on the things you just can't do off-the shelf...but if you can, alter your design with these things in mind.
-Stephen Kowski pointed this one out to me: don't ask "What Would Beatty Do?", ask "What Would BeachBots Do?". Look at 330 the past four seasons. Together, those robots have won one four regionals (and finalist at two more), Curie in 2007, IRI in 2008, and the whole enchilada in 2005. They're all dead simple; single joints for everything but 2006 (when an arm wasn't really an option). Build it as simple as possible, then refine that design as best you can. More time, shorter letter.
Unread 10-12-2008, 22:42
Lancer Robotics Lancer Robotics is offline
FRC #2437 (Lancer Robotics)
Lancer Robotics is a glorious beacon of lightLancer Robotics is a glorious beacon of lightLancer Robotics is a glorious beacon of lightLancer Robotics is a glorious beacon of lightLancer Robotics is a glorious beacon of light
Machine shop? Whats that? We are very fortunate in having a mentor who is very good at making flat material work like machined parts. With the extruced aluminum from Rexroth we made our own gussets from 1/8" alu,. Drill press for screws and lightening, 1/4 x20 t nuts and you can overcome a lot. We have to buy things like gears and sprockets and wheels, but that is the price to pay for not having access to a machne shop. A sander to round over edges and the famous buffing wheel.
not really hard and it gives a new challenge to the team.
Unread 10-12-2008, 22:50
EricH EricH is online now
And guess who has just about the resources you do? Yep, Team 330. Except it's a borrowed chopsaw instead of a bandsaw. The main thing you might want would be a welder, but that's negotiable. (It makes the robot look cooler, but you don't need it.) A machinist mainly does the absolute, 100% "it must be there and nowhere else" holes.
As to materials, 330's arm material of choice tends to be PVC or aluminum, depending on the year. (Fiberglass also works--2007.) Everything else is aluminum, but trannies are purchased or KOP. Steel only shows up in sprockets or in trannies.
Oh, and Billfred--you forgot a finalist at IRI 2005.
Unread 10-12-2008, 23:14
Honestly best thing I can suggest is go on google maps. Search "Machine shops in ' '"
We did it this year and learned that there are a bunch of machine shops that we never even knew about within 5 minutes of our school basically.
Google maps and Yellowpages, trust them.
Btw if you guys need further assistance feel free to PM or IM me and I'll see what contacts I can dig through for that area. I know of some....
Middlesex County College
http://maps.google.com/maps?f=q&hl=e...w=text&attrid=
Hope that this helps out. Btw 2554 is also in Middlesex County, see what they can help out with. Again, please IM or PM me if you need more help.
Unread 10-12-2008, 23:30
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
Hey bro, have I'm from team 2554 in Edison, NJ. We're pretty close to you guys. Anyways, have you guys pursued any on campus facilities? Does MCC have some kinda industrial arts department? You guys are literally part of the campus if I'm not mistaken?
I'll do some brainstorming for ya, so let me get back to you in a little bit.
Don't panic, we'll figure something out.
How far are you willing to travel btw?
Unread 11-12-2008, 04:34
Dragonos's Avatar
Dragonos Dragonos is offline
Web Master/ Engineer/ Programer
AKA: Eric G.
FRC #0095 (The Grasshoppers)
Dragonos is an unknown quantity at this point
Team 95 is going through the same possibility of not having a machine shop this year. It is really good that your team still has a bandsaw as this, the press and the gracious professionalism when handling an unfortunate situation like this. (We have worked out of a mentor's garage one year.)
Also don't let this happen to you use a wood block with the bandsaw.
http://wc.pima.edu/~cdiscenza/constr...saw_injury.jpg
-Dragonos-
PM me for 3dsMax Help!
Unread 11-12-2008, 10:15
Dick Linn's Avatar
no team (Synergy)
There must be three dozen machine shops in Middlesex/Piscataway/Plainfield. If you need the odd part turned or a slot milled, you can probably walk in and talk someone into doing it for free. On the rare occasions that Team 975 needed something machined, we've been able to find someone to do it.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 11-12-2008, 10:34
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
I'm going to echo this. If you don't have access to a machine shop kitbot is the way to go.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 11-12-2008, 12:42
waitwhat?'s Avatar
Driver Coach
AKA: Bunca
mcc is something like 30 minutes away, maybe 25. Also, I am open to suggestions as far as facilities. We dont really have a designated maximum that we are wiloling to travel, as long as its within reason.
Unread 11-12-2008, 13:40
Joining the 900 Meme Team
FRC #0079
Thirded!
397's robot was built using mostly 1 inch aluminum that we bent by hand. The only complex parts were the winch for raising our ball knocking device and the mounts for our cylinders. (We did them on a mill but I am pretty sure you could do them using a hand drill and a band saw if need be)
My suggestion would be to make sure your students can use the equipment safely and design knowing what you have to work with.
NEED SOME R/C ADVICE SCHIZOPHRENIA Technical Discussion 10 18-12-2006 09:39
Need some legality/possibility advice... IrishFBall32 Control System 3 26-04-2005 23:53
Chariman Winners .. need some advice David66 Chairman's Award 0 26-03-2004 23:13
i need some advice E Jones 234 Chit-Chat 11 17-12-2002 17:42
