Go to Post Really, flight? That is going to feed the rumor mill... - Munchskull [more]
Unread 11-12-2008, 08:25
bsikora bsikora is offline
bsikora is an unknown quantity at this point
Programming Question
I am a novice at easyC so here is my question.
Why when I am programming my VEX robot using easyC v2 my robot does not respond the same way when
bumper != 0
or
bumper == 1:
Can some one tell me why?
ahh:
Unread 11-12-2008, 09:58
AndrewN's Avatar
AndrewN AndrewN is offline
it's alive!
AKA: Andrew Nicholson
FRC #1778 (Chill Out)
AndrewN is just really niceAndrewN is just really niceAndrewN is just really niceAndrewN is just really niceAndrewN is just really nice
Re: Programming Question
C has a number of tests for comparing two numerical values:
== tests if the two values are exactly equal
!= tests if the two values are not equal
So the expression (bumper != 0) literally means "the value of bumper does not equal zero", it could be any value at all, other than zero, i.e. bumper could contain 3 and this expression would be true.
Where as the expression (bumper == 1) literally means "bumper is exactly 1". In the above example if bumper were 3 this would be false.
So for the values of bumper equal to 0 and 1, the two expressions are equivalent. For all other values they are not equivalent expressions.
In C when an expression is being used as a boolean value (true/false) the numerical value of 0 is treated as false. All other numbers are treated as true.
Aside: until recently C had no real boolean type.
You can use the operator ! to invert a boolean value.
So the expression ((!1) == 0) is always true, where as ((!0) == 1) is not necessarily true in all compilers, but is true in easyC.
If you are treating "bumper" as a boolean value then the expressions:
(!bumper) is a better test to check if bumper is false, and
(bumper) is a better test to check if it is true
instead of testing for equality against 0 and 1. These expressions clearly indicate that you wish to treat "bumper" as a boolean and you won't make any mistakes.
Hint: Be very careful about not using a single "=" where you should have used a "==". The "=" will set the value of bumper to what you thought you were testing against instead of not changing it. Get into the habit of writing "if (3 == myValue) { ... }" instead of "if (myValue == 3) { ... }" that way if you miss the second "=" the compiler will generate an error instead of silently doing an assignment.
Cheers!
Andrew Nicholson
2011 FRC Robot Inspector (Seattle, Portland)
Mentor FRC 1778 "Chill Out", FTC 3018, 3940 "Hawks", 4434 "Heat Misers"
"Everything should be made as simple as possible, but no simpler."
C programming question starchypizza Programming 2 18-11-2006 23:13
Programming question CircularLogic FIRST Tech Challenge 1 17-04-2006 21:52
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
C Programming Question tophq Programming 7 16-02-2004 12:56
Programming question archiver 2001 6 23-06-2002 22:57
