Go to Post We're not here to build robots. We're here to build students. - GreyingJay [more]
Unread 06-12-2008, 13:21
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Jaguar Failure
Has any team experienced a Jaguar failure (other than losing magical smoke)? I had many hours with the benchtop system up-and-operating and then the LED suddenly failed (as well as the output voltage). It was powered in the proper way (12 v battery through the PDB).
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 06-12-2008, 14:34
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
Re: Jaguar Failure
Just wondering how did it fail? Under heavy loads, or it just fried.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 06-12-2008, 16:21
Jon236's Avatar
AKA: Jon Mittelman
Re: Jaguar Failure
No load other than a van door motor (itself not loaded). No magic smoke. Autopsy revealed no carbon.
Jon Mittelman
Unread 06-12-2008, 16:23
Re: Jaguar Failure
Are the limit switch jumpers still installed?
Unread 06-12-2008, 16:28
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Jaguar Failure
Jaguars, like Victors, are sensitive to metal bits inside; they are somewhat more difficult to clean out though.
Unread 06-12-2008, 17:32
Jon236's Avatar
AKA: Jon Mittelman
Re: Jaguar Failure
Yes.......and no metal bits inside
Jon Mittelman
Unread 07-12-2008, 23:08
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: Jaguar Failure
We experienced a failure on two of our jags. Visit the link below. It is a large file.. about 20 meg so be patient. During the test both the victor and the jag are receiving the same signal. Power was applied to all three devices simultaneously. The two jags LEDs were both solid red and nonresponsive. The victor was still functional. The problem was repeatable by cycling power.
http://www.crosstheroadelectronics.c...uarFailure.avi
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 08-12-2008, 00:42
Lowfategg's Avatar
AKA: Tyler Moser
Re: Jaguar Failure
This is a bit worrying. Are they going to fix it or has someone informed FIRST of the problem?
Unread 09-12-2008, 17:38
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Jaguar Failure
Just wondering if there has been any new information on this. Was a cause of the failure found? A solution? Anything?
Unread 09-12-2008, 20:04
meastman meastman is offline
FRC #1245
meastman is an unknown quantity at this point
Re: Jaguar Failure
I was hoping that the jaguars would not fail easily. Last year we had to replace quite a few blown victors.
Unread 09-12-2008, 21:01
Re: Jaguar Failure
I am not certain of the cause. It appears to be a power-up issue. The Jags became nonresponsive (solid red LED as seen in the video) when power was cycled(applied then removed repeatedly). Here is my theory as to why. The Jag I believe uses an ARM processor. My experience with ARM chips is that they require more time to stabilize than most processors upon intial powerup. They have seperate voltages for the core and peripherals. The lock up could be caused from a timing issue between powering the core and peripherals. Again this is pure speculation. I am basing this on similar experiences with the Chicklet which also uses an ARM processor. Whatever the cause may be I hope FIRST addresses this issue prior to Kickoff.
They Jag seems like a very promising speed controller. It has great low-speed control and fast response. It supports CAN and can decode quadrature. All of this functionality is great but if the device locks up and causes a team to lose just one match, then as far as I am concerned the device is as good as garbage.
Mike Copioli
Unread 09-12-2008, 21:39
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: Jaguar Failure
So, are these Jags now fancy paper weights? When I hear the term "locked up" when it comes to electronics i make the assumption that you can power the item down and restart it and it will work normally.
Unread 09-12-2008, 21:44
billbo911's Avatar
Re: Jaguar Failure
Have these failures been reported to FIRST and Luminary Micro?? These units are so new, you won't find much help here. I suggest you go to the source.
Unread 10-12-2008, 07:31
Re: Jaguar Failure
I have not taken any steps thus far to report the problem to FIRST. I would like to perform a few more tests. However a problem like this would most likely have occurred during Beta testing of the product. I will contact LM today and inform them of the issue. This will at least give them a heads up to perform some tests of their own. The reason it was posted on CD was to inform the teams and see if they have had similar experiences.
Mike Copioli
Unread 11-12-2008, 14:50
utlinebacker's Avatar
utlinebacker utlinebacker is offline
AKA: Scott Emley
no team (Texas Instruments)
Team Role: Marketing
utlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud of
Re: Jaguar Failure
Luminary Micro is working with Mike to understand the issue he is seeing.
The initial speculation is that the inrush current due to the charging of the big bus capacitor in each Jaguar is causing the bench power supply to glitch causing a power on issue with the microcontroller. If this is indeed the case, it is very unlikely to affect battery operated systems.
More data will be generated when Mike has an opportunity to conduct further experiments in the team's shop. I'll respond back to the forum once I learn more.
By the way, I just updated the Jaguar microsite with the special Jaguar reorder link for FRC teams (through Digi-Key), a link to our technical support page, and a link to Luminary Micro's main webpage.
Regards,
Scott
Scott Emley
Marketing Manager
Texas Instruments
pic: Jaguar next to Victor ajlapp Extra Discussion 26 10-08-2008 17:56
pic: Jaguar... Under the Hood MasonMM Extra Discussion 14 09-08-2008 22:03
Compile failure darkChozo Programming 8 06-02-2008 20:49
motor failure redbarron Electrical 5 22-02-2006 10:52
Failure of Robot Interface Matt McNelley Technical Discussion 23 08-04-2003 21:32
