Go to Post Yes ONE blue banner would be nice one of these days, but I've never lost focus of why we as mentors do what we do. It's about preparing the students for "defense" in life, and laugh when your robot gets scored into a goal. - Chris_Elston [more]
Unread 11-12-2008, 15:22
spc295 spc295 is offline
FRC #0295 (Renevatio)
spc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to behold
chain wrap
how much is the minumum that 25 pitch chain needs to wrap on a sprocket, with average tension. is there some kind of rule?
295 Team Captain
Unread 11-12-2008, 15:31
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: chain wrap
180 is ideal. I've done 120 with some success but it's not as smooth and will slip under directional changes depending on tensioning.
-Vivek
"we don't build robots, we build people"
Unread 11-12-2008, 15:37
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: chain wrap
-Vivek
+1
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 14-12-2008, 10:25
Dick Linn's Avatar
no team (Synergy)
Re: chain wrap
From Diamond Chain: http://www.diamondchain.com/support/techfaqs.php
What is the recommended minimum chain wrap in a roller chain drive?
ANSWER: The recommended minimum wrap angle of the smallest sprocket in the drive is 120°. The wrap angle can be reduced to 90°, if good chain tension adjustment is maintained. If chain tension is not closely maintained with less than 120° wrap, the chain can jump teeth, resulting in damage to the chain and/or the sprocket.
Note: For a sprocket ratio of 3:1 or less there will always be 120°or more wrap on the small sprocket, regardless of the center distance.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 14-12-2008, 11:45
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: chain wrap
Originally Posted by Dick Linn View Post
From Diamond Chain:
That is true, assuming only two sprockets....but if you have more than two sprockets in the system, things get more complicated.
Unread 14-12-2008, 13:20
vivek16's Avatar
AKA: vivek
Re: chain wrap
Yeah, don't forget idler sprockets.
Which reminds me, you can often use idlers or tensioners to ensure more chain wrap.
-Vivek
Unread 14-12-2008, 13:22
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
Re: chain wrap
I believe maximum recommended tension for #25 chain is about 300 pounds. Not sure about minimum, but generally good tension is where you can pull up the chain just slightly (about 1/2" to 3/4" from horizontal depending on length of the stretch of chain) in the middle of the chain stretch. If you're tensioning the chain and you see the links begin to deform at all, it's too tight. Under proper tension, the chain should eventually stretch out and require retensioning.
Unread 14-12-2008, 13:59
Dick Linn's Avatar
no team (Synergy)
Re: chain wrap
It is my considered impression that chain doesn't "stretch", except under extreme load. Elongation is due to wear, though it could happen due to exceeding the elastic limit. Chains are not guitar strings, so don't "tension" them. If a chain wears and elongates more than a couple of percent, then you'll have problems with tooth spacing and are in a world of hurt.
Have a look around here: http://chain-guide.com/toc.html
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 14-12-2008, 14:06
MrForbes's Avatar
AKA: Jim
Re: chain wrap
I agree, chains wear in, they don't stretch. Once they get some wear at the contact points, they don't elongate much more.
Unread 14-12-2008, 14:29
Dick Linn's Avatar
no team (Synergy)
Re: chain wrap
Short runs of quality #35 chain are your friend.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 15-12-2008, 09:39
dpeterson3 dpeterson3 is offline
FRC #1178 (DURT)
dpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the rough
Re: chain wrap
This may just be from working on bikes, but chains seem to stretch to a certain point after their break-in period. Just use a system like we did last year. We had a skate-board wheel with springs pulling it back to put tension on the chain. We had no problems and didn't have to mess with calculations and angles. If you can't put it on the inside of the chain, push against the outside. You need some kind of tensioning. Good luck.
Position idlers to get better chain wrap -- a question about good practices. Madison Technical Discussion 23 31-01-2008 09:35
Curie Wrap-Up cziggy343 Championship Event 0 14-04-2007 20:07
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
Wrap Party buzzy Championship Event 7 15-03-2004 00:01
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
