#18
Re: Team 869 In Need of Some Advice
One thing that will help out with metal working without a machine shop is a cheap used copy of AutoCAD, a can of spray adhesive, and a plotter printer.
If you Cad all of the parts you need to make out of sheet metal you can print life-size versions of your drawings and use the spray adhesive to stick the image on to the sheet metal of your choice. This way you can get the precision of a machine shop with hand tools. |
| NEED SOME R/C ADVICE | SCHIZOPHRENIA | Technical Discussion | 10 | 18-12-2006 09:39 |
| Need some legality/possibility advice... | IrishFBall32 | Control System | 3 | 26-04-2005 23:53 |
| Chariman Winners .. need some advice | David66 | Chairman's Award | 0 | 26-03-2004 23:13 |
| i need some advice | E Jones 234 | Chit-Chat | 11 | 17-12-2002 17:42 |
