Go to Post if you do make a marshmallow robot, that would be pretty sweet. - smurfgirl [more]
Unread 02-12-2008, 20:06
nickmagus's Avatar
nickmagus nickmagus is offline
AKA: Nick Clayton
FRC #0008 (Paly Robotics)
nickmagus is an unknown quantity at this point
Send a message via AIM to nickmagus
inconsistent wireless code downloading
Has anyone else encountered the error that when you download code the code does not change. I usually have to download code 4-5 times before the code actually changes on the cRIO. Does anyone know whats up with that?
Unread 02-12-2008, 20:28
Re: inconsistent wireless code downloading
Which environment were you using, and can you describe your test so that we can try to replicate?
Greg McKaskle
Unread 02-12-2008, 22:20
If you download to the cRIO's flash, you have to reboot it in order for the fresh copy of the code to be run. If you download to RAM, it should run immediately.
(If you are experimenting with both LabVIEW and C++ programs, you might accidentally end up with two different programs running simultaneously, with obvious confusion. Don't do that.)
Unread 03-12-2008, 01:36
willson.thomas willson.thomas is offline
FRC #1595
willson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nice
I thought you had to change the development environment using the cRIO imaging tool before loading a program from the other development environment. Wouldn't this some how prevent the above from happening? If not, shouldn't it?
Team Leader
Team 1595
Unread 03-12-2008, 09:00
Changing the development environment is really only necessary to get the debugging systems fully functional. It is possible to run LV on a C system, C on a LV system, and yes, both at once. After all the LV system is just a C program that is making calls into generated LV code, so the OS doesn't know the difference.
The debugging differences have to do with how exceptions are caught, or something like that. I have never looked at the details. I normally run the tool.
Greg McKaskle
Unread 04-12-2008, 20:03
nickmagus's Avatar
AKA: Nick Clayton
So I did some testing and here is what I found. I'm using windriver and C++. If I use the debug method of running code on the robot through the RAM everything works fine however if I download the code and reboot the robot the two modes (teleop and autonomous) dont change until the robot is not in their mode. I did a really simple test (switching joysticks in teleop) and found that if i reboot the robot in teleoperated mode the joysticks wern't switched but i switched to autonomous and back it worked. the same thing happened with autonomous. any ideas whats up?
Unread 05-12-2008, 09:11
...if I download the code and reboot the robot the two modes (teleop and autonomous) dont change until the robot is not in their mode.
I'm sorry, but I have no idea what this means. Can you give a less general description?
The term "switch" apparently means more than one thing here, and I can't tell what is intended. Let me rephrase my question. Can you give a more step-by-step description of what you did, what you expected to happen, and what happened instead?
Unread 11-12-2008, 17:57
nickmagus's Avatar
AKA: Nick Clayton
sry i forgot to post that i figured out what was happening. thanks though.
Problem downloading code Romeo1351 FIRST Tech Challenge 6 01-12-2006 06:33
Downloading code to 2005 RC Eclipse Control System 2 23-02-2006 19:58
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
Problem downloading any Camera code zuckie13 Programming 4 07-02-2005 20:32
Downloading Code with new Editor gburlison Programming 4 17-01-2003 01:10
