Go to Post Yeah, you build robots, so what. But you also build students, and that's what it's about! - DonRotolo [more]
Unread 11-12-2008, 20:52
waitwhat?'s Avatar
waitwhat? waitwhat? is offline
Driver Coach
AKA: Bunca
FRC #0747 (Flight Crew)
waitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant future
Re: Team 869 In Need of Some Advice
Originally Posted by IKE View Post
While there is some great advice out there, I have a few questions?
Historically speaking,
How much have the kids made in the past?
What parts did you make in the past that can't be made with a bandsaw and/or drill press?
What experience level does your team have as far as building stuff?
Looking at your previous bots, I would have to agree that if you can't find a welder (both machine and person to do it), you should try to plan towards bolt together stuff.
With AM and the state of the KOP (assuming it is good again this year), you can definitely get by without a Shop. That being said, make sure that you work on it for next year as there are a lot of good lessons that can come from working with a shop.
Just to clear things up, our machine shop had originally put together an arrangement that was a bit unordinary. Our team was allowed to use the machine shop, and the machinists tought the students how to operate the mills, lathes and welders. We have a descent amount of machining experiance on the team, but we have no equipment.
NEED SOME R/C ADVICE SCHIZOPHRENIA Technical Discussion 10 18-12-2006 09:39
Need some legality/possibility advice... IrishFBall32 Control System 3 26-04-2005 23:53
Chariman Winners .. need some advice David66 Chairman's Award 0 26-03-2004 23:13
i need some advice E Jones 234 Chit-Chat 11 17-12-2002 17:42
