Go to Post The championship could be in a swamp infested with flying insects, and it would still rock the world :D - kristen [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 11-12-2008, 20:55
fabalafae's Avatar
fabalafae fabalafae is offline
Guardian of the Grimmerie
FRC #0540 (TALON)
fabalafae is an unknown quantity at this point
Coefficient of friction
Does homework help go in this section of the forums? If it doesn't, can I get help anyway, please?
Does anyone know the static or kinetic coefficients of friction for rubber and tile/table/some smooth surface?
The only coefficients I've found online are between rubber and asphalt/concrete.
Thanks...
I am stricken and can't let you go
When the heart is cold, there's no hope, and we know
That I am crippled by all that you've done
Into the abyss will I run
Unread 11-12-2008, 21:28
Carlee10's Avatar
Carlee10 Carlee10 is offline
Loves F.I.R.S.T.!!!!!!
FRC #1529 (CyberCards)
Carlee10 is a splendid one to beholdCarlee10 is a splendid one to beholdCarlee10 is a splendid one to beholdCarlee10 is a splendid one to beholdCarlee10 is a splendid one to beholdCarlee10 is a splendid one to beholdCarlee10 is a splendid one to beholdCarlee10 is a splendid one to behold
Re: Coefficient of friction
I've got my physics book, and it has the numbers for
'rubber on other solid surfaces". The static is 1-4, and kinetic is 1. I hope that helps.
Attending- College!
Awards: BMR's 2008 Judges Award
"Courage is not the absence of fear, but rather the judgment that something else is more important than fear. The brave may not live forever, but the cautious do not live at all."- Movie quote
Unread 11-12-2008, 22:50
joshy1323 joshy1323 is offline
AKA: josh anderson
FRC #1323 (madtown robotics)
joshy1323 will become famous soon enoughjoshy1323 will become famous soon enough
1) what kind of rubber?
2) exactly what smooth surface?
3) by time you get help on this homework will it already be too late anyway?
----1323 josh
Unread 14-12-2008, 12:51
fabalafae's Avatar
FRC #0540 (TALON)
Hahah, yeah it's too late now. But thanks anyway.
Unread 16-12-2008, 22:35
AKA: josh anderson
no problem. sorry i wasnt fast enuff....
----1323 josh
Help! Calculating drag coefficient in Autodesk Inventor? brennerator Technical Discussion 2 12-03-2007 01:19
Coefficient of Friction VEN Technical Discussion 10 30-12-2006 18:36
Coefficient of friction of tetra suneel112 Kit & Additional Hardware 1 12-02-2005 15:40
Skyway Coefficient of Friction HPA_Robotics_13 Kit & Additional Hardware 1 25-01-2005 06:26
Coefficient of Frictions mzitz2k Technical Discussion 15 06-01-2004 20:16
