Go to Post Right, play to win. Play to win the event or play to win one match? This year, unfortunately, they are not the same thing. - Paul Copioli [more]
Unread 11-12-2008, 13:59
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: Team 869 In Need of Some Advice
80-20 is awesome stuff.
It used the original kitbot parts, plus some additional parts we ordered.
The only thing we couldn't do with out a bandsaw or drill was the welding of the chassis. We had to send it out for that.
Unread 11-12-2008, 15:38
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
1501 seems to build there bot every year using monocouque, pretty much just sheetmetal and rivets. (about 1,600 rivets ). Its great, and its what the aircraft industries use. It takes some practice, but our tools are pretty much a drill press, pneumatic metal shears, and a tabletop belt sander. We also use some chromoly tubing, and that will reguire some welding. But monocoque can easily be integrated into a kitbot frame.
go to huntingtonrobotics.org for some inspiration. Click on the photos icon at the top, and then select 2008 build season. (you may have to hit the back "more photos" button on the lower left hand side. It may be back a page)
Unread 11-12-2008, 15:56
JAZAD1's Avatar
JAZAD1 JAZAD1 is offline
Assisant Coach
AKA: Zach
FTC #4105 (Teal Toranadoes)
JAZAD1 has a spectacular aura aboutJAZAD1 has a spectacular aura about
The only thing that I can think of is find materials that are approved premade things that would be easy to modify to fit the game and the robot. But you could use the same theory our team has used for the past 3 years that seems to work KISS (keep it simple stupid) make sure that what ever you do can be done over and over again so if it breaks it can be fixed and you don't have to change the whole robot to fix a problem. (Ex you don't have to take out the transmission to get to the electrical problem that could be fixed in seconds after you figure out what the problem is) A reliable robot is a good robot. We try to look at it as a robot that can do our goal all of the time even though it may not be the most points in the game we can do it every time without a problem. I believe that the one thing that you should focus on with a limited amount of resources is a drive train. You can still be a competitive robot even though the manipulator may not be top notch but you are always moving during the two minutes (hopefully). If you need me to clarify any of this please message me.
2010 IRI FRC Second Place Finisher
2010 International Championship Coopertition (Galileo)
2010 International Championship #1 Seed (Galileo)
2010 NC FRC Motorola Quality Award
2010 NC FRC Regional Winner
2010 VA FRC Regional Winner
2010 VA FRC Engineering Inspiration
2009 VA (S) FTC Inspire Award
2009 VA(S) FTC Division Finalist
2009 VA FTC PTC Desgin Award
2009 International Championship Spirit Award
2009 VA FRC Regional Champion
2009 VA Regional Chairman's Award
2009 VA Website Excellence
2008 VA FTC Regional Champion
2008 VA FRC Regional Champion
2008 VA Regional Chairman's Award
2008 VA Xerox Creativity
Unread 11-12-2008, 16:05
Doctorwho's Avatar
Doctorwho Doctorwho is offline
FRC #0467
Doctorwho will become famous soon enoughDoctorwho will become famous soon enough
One thing that will help out with metal working without a machine shop is a cheap used copy of AutoCAD, a can of spray adhesive, and a plotter printer.
If you Cad all of the parts you need to make out of sheet metal you can print life-size versions of your drawings and use the spray adhesive to stick the image on to the sheet metal of your choice. This way you can get the precision of a machine shop with hand tools.
Unread 11-12-2008, 19:19
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
While there is some great advice out there, I have a few questions?
Historically speaking,
How much have the kids made in the past?
What parts did you make in the past that can't be made with a bandsaw and/or drill press?
What experience level does your team have as far as building stuff?
Looking at your previous bots, I would have to agree that if you can't find a welder (both machine and person to do it), you should try to plan towards bolt together stuff.
With AM and the state of the KOP (assuming it is good again this year), you can definitely get by without a Shop. That being said, make sure that you work on it for next year as there are a lot of good lessons that can come from working with a shop.
Unread 11-12-2008, 19:51
guakam0li1089 guakam0li1089 is offline
FRC #1089 (Mercury)
Team Role: Communications
guakam0li1089 will become famous soon enough
perhaps you should also try working with spare medal to see if you can build what you designed using tips from the above posters. also, if you havent already, try asking your local home depot, lowes, or other hardware store that has a shop if they will sponser you
Wise men talk because they have something to say; fools, because they have to say something.
Unread 11-12-2008, 20:11
Another brilliant example of basic kit chassis is 121. That's how they build a beastly robot and always have like half of build to practice driving.
(Of course it is modified)
Unread 11-12-2008, 20:52
waitwhat?'s Avatar
waitwhat? waitwhat? is offline
Driver Coach
AKA: Bunca
FRC #0747 (Flight Crew)
waitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant future
Just to clear things up, our machine shop had originally put together an arrangement that was a bit unordinary. Our team was allowed to use the machine shop, and the machinists tought the students how to operate the mills, lathes and welders. We have a descent amount of machining experiance on the team, but we have no equipment.
Unread 11-12-2008, 22:02
Aarnat's Avatar
Aarnat Aarnat is offline
Senior Captain
AKA: Aaron
FRC #2199 (Robo-Lions)
Aarnat will become famous soon enoughAarnat will become famous soon enough
That partnership you had with the machine shop is something that only a few teams are blessed with. I’m sincerely glad you had that opportunity. Obviously, the bad news is you don't have that anymore or machines for that matter. The good news is that you can take that experience with you elsewhere, including into your careers.
Our team, 2199, is in its 3 year. We used the old workshop in our high school that was rarely used. It had band saws, drill presses, and hand tools and managed fairly well to build a great robot. We also have been steadily adding our own set of hand tools. This year, new classes were created and now use that area daily (and I know because I'm in that class) and because of the lack of space to lock things up to keep everything secure, we had to move. Fortunately, last year we were given an empty warehouse space, managed by one of the student's father, walking distance (15 minutes) from the school. Getting that area was accomplished just by asking. Your team can go around the local area and find a new work space.
We moved there to practice near the end of the build season. This year, the father and his business then let us use his work area as well as keep access to the bigger warehouse room we practiced in. We have already started to clean up the space, organized it, and apply for grants to fill the space with tools.
Anyway the point is:
-Find a space through a massive organized “public relations” movement to all the local shops and warehouses
- If that doesn’t work find a team member's garage (we did our first two years when we were working on the weekends and couldn't get into the school)
-Clean up your area
-Buy essential tools with team’s money, grants, or sponsorships.
-You have 22 days or less
-You may not have the fanciest equipment, but you can still build a reliable robot. We have and so has many other teams.
Good Luck!
NEED SOME R/C ADVICE SCHIZOPHRENIA Technical Discussion 10 18-12-2006 09:39
Need some legality/possibility advice... IrishFBall32 Control System 3 26-04-2005 23:53
Chariman Winners .. need some advice David66 Chairman's Award 0 26-03-2004 23:13
i need some advice E Jones 234 Chit-Chat 11 17-12-2002 17:42
