Go to Post steve, don't hurt me - Alex Cormier [more]
Unread 12-12-2008, 03:49
shavol shavol is offline
AKA: Shahar Givol
no team (Elysium)
shavol is an unknown quantity at this point
definition of FUNCPTR
Hello, I am looking at the WPIlib code and have a question
in task.h line 39 I found the variable type 'FUNCPTR' and I didn't found the definition of it in the project, do you know what is the definition of it?
thanks a lot,
team 1937.
Unread 12-12-2008, 07:35
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
Re: definition of FUNCPTR
I am not certain which file it is defined in but what it is is a function pointer. It allows you to pass around a reference to functions of the same signature (same return type and parameter types). Function pointers are often used for callbacks where you will provide some function a pointer to a function they should call when some event happens. Wikipedia has a pretty good overview in their Function pointer article.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 12-12-2008, 08:14
2roy999 2roy999 is offline
FRC #1937
2roy999 is an unknown quantity at this point
Hello, I read what you wrote and I have a question
How can I know the return type of the function and the type of the function's arguments?
thank you,
Team 1937
Unread 24-12-2008, 15:46
GabeRC1717's Avatar
GabeRC1717 GabeRC1717 is offline
FRC #1717 (D'Penguineers)
Team Role: Student
GabeRC1717 is on a distinguished road
typedef int (*FUNCPTR)(...);
You can have up to ten arguments, they have to be of the type "int", see taskSpawn
Gabe
grivescorbett@dpengineering.org
Team 1717, http://dpengineering.org
Unread 27-12-2008, 06:06
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Soo... a function pointer holds the address of a function, it's arguments and return type?
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
Unread 27-12-2008, 07:19
Boiler Up
AKA: John Downey
Close, it is just the address of the function. You define the types for the parameters and return and the compiler will setup the function call correctly for you. It will also (if it can) double check that you are calling the function with the correct signature (signature being types of return and parameters) to prevent simple mistakes.
John Downey
Unread 28-12-2008, 19:00
Dbruce1792 Dbruce1792 is offline
FTC #0130
Dbruce1792 is on a distinguished road
Originally Posted by GabeRC1717 View Post
Can't the int be typecast as a float, etc.?
pwm definition problems Anton Programming 4 02-02-2005 13:01
Its-Definition Please archiver 2000 4 24-06-2002 00:08
Definition of aluminum extrusion...? kangarue23 Technical Discussion 4 25-01-2002 16:53
