#9
Re: Camera
Personally, I am opposed to breaking something that is already working.
2009 FRC Control System Manual: Section 3 – Component Datasheets, Rev 0.5 "How do I build a cable for passing 5V power to the Ethernet camera? • Take the camera’s power adapter (PN SA106A-0512-6) and cut the wire off close to the Wall-Wart. o Note: There are two power adapters for the camera included in the Kit, one in the camera box and one separate. Use the separate one (PN SA106A-0512-6) to make this adapter. • Separate the wires and strip 5-6mm off the ends. • Use a small flat head screwdriver to open the WAGO 739-302. • Insert the positive (striped) wire in the right port. Note: the correct orientation can be verified by looking at the silk screen on the PD Module. • Insert the negative wire in the left port. • Give a smart tug to verify the connection is secure. • Power the PD, and verify that the barrel connector’s center conductor is positive." I bet if you take the power adapter to Radio Shack(Digikey, Mouser, etc.), you will find a connector that you can wire yourself. |
| Tell the difference: 2007 CMU Camera, 2006, 2005 camera? | Chris_Elston | Programming | 2 | 07-01-2008 13:11 |
| CAMERA | Slick | Programming | 30 | 10-02-2007 13:30 |
| Camera | The yellowdart | General Forum | 4 | 21-01-2007 22:56 |
| Camera Help (New to Camera Programming) | Idaman323 | Programming | 6 | 14-01-2006 03:56 |
| Camera Malfunctions | Alex698 | Programming | 1 | 04-02-2005 18:32 |
