Go to Post To limit FIRST to robots, tools, and competition is to strip away its immense potential. - Madison [more]
Unread 12-12-2008, 11:02
ZeroValue ZeroValue is offline
FRC #2122
ZeroValue will become famous soon enoughZeroValue will become famous soon enough
Dual spoke wheel
Instead of a one set of spokes in the middle of the wheel, I have half a set on each side of the wheel. Its still possible to machine it, one side is simply the pastern on the other side rotated thirty degrees. OD is 4" and the hex on the inside is 3/8" flat to flat.
Unread 12-12-2008, 11:23
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Dual spoke wheel
Neat! now if you move the outer ends of the spokes more towards the center of the wheel, you'll have a reasonable copy of an old racing wheel design!
Unread 12-12-2008, 14:27
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Very nice! This is similar to our 4" tank tread wheel we developed--took a 4 lb. solid aluminum wheel and turned into just over 1 lb.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
pic: Dual Wheel Swerve-Drive =Martin=Taylor= Extra Discussion 5 28-04-2007 01:21
Dual wheel per axle set crab-steer concept Andrew Schuetze Technical Discussion 8 21-06-2006 08:55
pic: Dual omni-wheel Richard Wallace Extra Discussion 17 05-12-2005 10:38
Bush spoke on FIRST Ryan M. Chit-Chat 15 01-11-2004 16:32
White Paper Discuss: Dual-motor, dual-speed gearbox CD47-Bot Extra Discussion 8 05-04-2004 19:24
