Go to Post WHAT!?!?!? YOU DON'T DEVOTE YOUR LIFE TO APPLE!?!?!?!? ;) :p - Joe Matt [more]
Unread 12-12-2008, 21:32
darkpheonix darkpheonix is offline
FRC #2225
darkpheonix is an unknown quantity at this point
How do you program joystick buttons in LabVIEW?
Hi guys,
How do you program joystick buttons in LabVIEW, or program anything with the joystick for that matter? I kinda figured out how the drive VI and joystick get axis VI work but I'm lost on how to use the joystick get VI to do anything else. I'm totally new to LabVIEW so any help would be appreciated.
Unread 13-12-2008, 00:03
ZInventor's Avatar
ZInventor ZInventor is offline
AKA: Zeno Le Héricy
FRC #2915 (Riverdale Robotics Pandamonium)
ZInventor is just really niceZInventor is just really niceZInventor is just really niceZInventor is just really nice
Re: How do you program joystick buttons in LabVIEW?
here's a simple program i wrote to output the data from my USB COMBATSTICH 568
it just displays the outputs, but it should help you get started...
the data is oupput as clusters, that you can unbundle, and use the data from...
-Z
[center]
Unread 13-12-2008, 00:51
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
Are we talking about getting it off the DS, or off a joystick plugged into the computer?
If the second, then ZInventor's VI should work, if you're looking for help for this year's control system, then see the attached. Joystick Get outputs 2 bundles, one with 12 booleans (for the buttons), the other with 6 doubles (for the axises (I've never seen more than 3 though...))
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 09-04-2014, 07:06
bol_clubiste's Avatar
bol_clubiste bol_clubiste is offline
bol_clubiste is an unknown quantity at this point
I don't have joystick Get function in my palette , what should I do please ?
Unread 09-04-2014, 19:50
EDesbiens's Avatar
EDesbiens EDesbiens is offline
Passionate crackpot
AKA: Étienne Desbiens
FRC #5859 (i)
EDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of light
To get it, just do like on this image:
Unread 09-04-2014, 19:53
This is a forum for the FIRST Robotics competition, which has it's own LabVIEW library. The FIRST Library will not do what you want. I recommend asking at the NI Community forums for a general answer.
Unread 09-04-2014, 20:00
Thank you ! I already have looked in the Net about this problem and I found that I must install WPI Robotics Library , but I coudn't find a link or a site to download , Please can you give me a link ?? thank you very much brother
Unread 09-04-2014, 22:51
Unless you're going to be controlling a National Instruments cRIO-FRC with associated I/O hardware and a networked Driver Station, the WPI library won't do anything helpful for you. For reading joysticks, what you probably want is in the Connectivity -> Input Device function palette.
Unread 10-04-2014, 01:30
tcjinaz tcjinaz is offline
Tim
FRC #3853
tcjinaz has a spectacular aura abouttcjinaz has a spectacular aura about
Look for Connectivity->Input Devices
There are joystick & keyboard functions there. I have been using them to explore the SpaceMouse and the Logitech GamePad interfaces.
Software Mentor
3853 Pridetronics[
Unread 10-04-2014, 07:13
EDesbiens's Avatar
Passionate crackpot
FRC #5859 (i)
But, do you have the FRC version of Labview?
Unread 13-04-2014, 10:20
pastelpony's Avatar
pastelpony pastelpony is offline
Programmer/Electrical
AKA: Zach M
FRC #3525 (Nuts and Bolts of Fury)
pastelpony will become famous soon enough
Wire an "unbundle by name" to the "buttons" output on the joystick "Get" command. The buttons generated will be treated as booleans and can be used in tandem with case structures, subVIs, etc to complete an operation with a button press.
Tip if you ever want to program network applications in LabVIEW Michael Hill National Instruments LabVIEW and Data Acquisition 1 24-10-2008 20:31
Programing joystick buttons Shivang1923 Programming 8 09-02-2008 16:21
Buttons to Pins on Joystick yarb65 Electrical 1 24-08-2007 20:39
How many buttons do you have? Bcahn836 Chit-Chat 12 01-09-2004 23:34
Does anyone have an idea on how to make a joystick program for an operating board? necroprime Programming 8 09-11-2002 19:04
