#18
Re: Sliding axle tension system
One issue not even addressed is that the only thing keeping the two bearings concentric is the axle. This is the reason we make ours have the two halves slide together. Then all the force is on the bearing housing itself and not side loading the shaft.
| sub-team tension??? | Darkswordsmith | General Forum | 18 | 10-02-2006 21:35 |
| Buying spare Sliding Door Motors | cab2137 | Motors | 10 | 16-02-2005 11:54 |
| Sliding door motor shaft support | Max Lobovsky | Motors | 3 | 14-01-2005 18:39 |
| Globe motor, Sliding Door | Coachmac | Motors | 3 | 12-01-2005 14:11 |
| sliding boxes | Jeff Rodriguez | General Forum | 11 | 11-03-2003 00:24 |
