Go to Post There are few times I sleep so soundly as I do after an FRC build season and regional. - JamesCH95 [more]
Unread 10-12-2008, 13:42
Jill Jill is offline
FRC #2197 (Las Pumas)
Jill is an unknown quantity at this point
Camera detection
I set the static IP address to 192.168.0.90 and plugged in the camera, but the setup wizard doesn't detect it. The camera's lights turn on, so it's getting power. I've tried being both connected and disconnected from the school's wireless network, and I get two different error messages. When I'm connected to the wireless network, it says "Unable to connect to camera. Ensure the camera is connected to the PC and IP settings are correct." Otherwise, it says something about entering "FRC" as a username and password. Any ideas?
Unread 10-12-2008, 13:46
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
Re: Camera detection
Where did you set the static address? The FRC Programming Guide says to set the PC address to 192.168.0.90. That is the same address as the camera. Set the PC to another address such as 192.168.0.6 as suggested in the Control System Manual. Also, I had to disable the firewall for the camera setup program to run correctly.
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Are you using a cross over cable to connect to the camera?
Unread 10-12-2008, 16:31
darkember darkember is offline
AKA: Billy
FRC #0375 (Robotic Plague)
darkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of light
Turn off the proxy which is under LAN settings.
Unread 12-12-2008, 17:00
I tried everything except turning off the proxy... any ideas on how to do that in Vista?
I even managed to discover yet another error message:
"Unable to complete operation because of unexpected error %d:
%s63 TCP Open Connection in Axis Issue HTTP Request with Authentication.vi->Axis Issue Get.vi->Axis Create FRC User.vi->Dialog.vi"
which makes me wonder if I'm missing a file somewhere. Is anyone else having such a difficult time with this camera?
Unread 12-12-2008, 17:16
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Make sure you dont set your PCs IP address to 192.168.0.90. That's a misprint in the manual. Set it to something like 192.168.0.20 and it'll work just fine.
Unread 12-12-2008, 19:04
Yet another error message:
"Unable to log into the camera. Manually create a user with username "FRC" and password "FRC", or restore the camera to the factory settings and run this program again."
Unread 12-12-2008, 22:37
AKA: Billy
To turn off the proxy you go to internet options and then you go to LAN settings. You can turn off proxy from there. How are you trying to connect to the camera? We used the camera management tool to locate the camera, then we browsed 192.168.0.90 (making sure that our computer static ip wasn't set to the same address). Once you get to a screen that shows you how to configure the camera you just go to the user page. After saving you go to the camera video icon. You go to camera settings, add camera, search camera. Once you do that you should be recieving images from the camera. I hope this helps you guys out in solving your problem.
P.S. It took us 2 days to figure that camera configuration out so you aren't the only ones who had trouble with it.
Unread 13-12-2008, 22:08
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
Did you follow the steps in section 5.5 (page 9) in the FRC Control System Configuration document about changing the username and password on the camera?
Unread 13-12-2008, 22:25
lenny8's Avatar
lenny8 lenny8 is offline
Aww Yea
AKA: L-Deezy
lenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to behold
hmmm that sounds familiar.......
Learn something, Know Something, Do something
Unread 14-12-2008, 00:29
KevinReid's Avatar
KevinReid KevinReid is offline
FRC #2609 (Beaver worX)
KevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to behold
We did the same thing, just connect to the camera directly with laptop and setup a new user: FRC and password: FRC
Ganged Interrupt Edge Detection cprogrammer Programming 8 01-02-2008 10:52
rangefinding/object detection sciguy125 Electrical 14 13-01-2008 20:36
Tell the difference: 2007 CMU Camera, 2006, 2005 camera? Chris_Elston Programming 2 07-01-2008 13:11
Camera Help (New to Camera Programming) Idaman323 Programming 6 14-01-2006 03:56
Collision Detection in Inventor? jlewellen Inventor 2 06-01-2005 21:29
