Go to Post That wheel appears to have been forged deep within the fires of Mount Awesome. - viking1902 [more]
Unread 14-12-2008, 05:59
beefy1 beefy1 is offline
None #2669
beefy1 is an unknown quantity at this point
gyro values
hi, im pretty new with the wpi library, some one can tell me which values does the gyro yield and what they are symbolized, i mean, if the gyro is about to 360 degrees - then the value will be zero or 360? , some special values that can screw up my plan.
Unread 14-12-2008, 11:37
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Re: gyro values
You kinda have to understand the gyro works. It detects in rate of change in angle (d/dtheta), so you have to integrate (calculus, yay!) the input data to get the angle.
Now how the method works, (or I think it works, I haven't played around with the new WPI lib) is that it integrates the input data while subtracting the initial voltage (something like 1.25v).
To answer your question, lets say you start off. You turn it on and the sensor intializes. The angle is then zero, you turn it counterclock wise, the values goes from 0 to 360 then to 720, etc. etc. but if you turn it on and turn it clockwise, you get values from -1 to -360 then to -720 and onwards.
Unread 15-12-2008, 09:05
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
Re: gyro values
Before you can use any sensor in software, you need to start with the data sheet for the sensor.
Here is the link to the sensor manual for last years kit:
http://www.usfirst.org/uploadedFiles...sor_Manual.pdf
For full information determine the manufacturer and the manufacturer's part number for the component of interest and go the manufacturer's website for a complete data sheet.
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Unread 15-12-2008, 09:51
Re: gyro values
You shouldn't assume you can use any sentinel values from the gyro angle.
penalties values??? colin340 Rules/Strategy 4 08-03-2008 21:37
Paint values capenga Programming 1 20-02-2005 13:25
Servo Values DanDon Motors 8 14-02-2005 15:49
Color Values WesleyBalmer Programming 3 15-01-2005 22:26
PWM Values... Ian W. Programming 4 17-03-2002 21:53
