Go to Post ...I've changed my position. I'm fully supportive of Joe's suggestion... - Chris Hibner [more]
Unread 14-12-2008, 14:30
Jazonk's Avatar
Jazonk Jazonk is offline
It's all a balancing act.
AKA: Dino
FRC #0027 (Team RUSH)
Team Role: Driver
Jazonk will become famous soon enough
Send a message via MSN to Jazonk
Anyone know how to get a live video feed from your axis cam?
We hooked up the camera to a pc and got a video feed, then when we put it on the robot the screen was blank. the ethernet port on the cRIO wans't blinking...anyone know how to do it?
Unread 14-12-2008, 14:55
Re: Anyone know how to get a live video feed from your axis cam?
Did you use the special orange cross-over ethernet cable to connect the camera to the cRIO port 2?
Unread 30-12-2008, 16:46
ShotgunNinja's Avatar
ShotgunNinja ShotgunNinja is offline
Programming Mentor, FRC 4247
AKA: Nicholas Iannone
FRC #4247 (CougarBOTS)
ShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the rough
I did find an open-source C#-based program called CV (Google it) that lets you hook into and view feeds from IP cameras such as the one shipped with the 2008-2009 kit.
Also, the format is HTTP-packeted MJPEG (Moving JPEG), I believe, similar to any standard IP camera. You could probably just use VLC Media Player to watch it live.
Team #2970 Alum
Team #1652 Alum
2006: School Mascot for Team 1652
2007-2008: Programmer for Team 1652 (Robot Mafia)
2009: Programmer on Team 1652 (Robot Mafia), Programmer on Team 2970 (eSchool eBots)
2010-2016: Volunteer, Wisconsin Regional
2017: Programming Mentor, FRC 4247 (CougarBOTS, Obama SCTE, Milwaukee, WI)
Unread 30-12-2008, 23:35
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
I'd also like to get some more information on this topic. We as a team have configured the webcam according the the control system manual and got a live feed when we were directly hooked to the camera. We then hooked it back up into port 2 and wanted to try to view the camera another way with no success.
Is there anyway to view a live feed wirelessely or by hooking up a laptop to the router or driver station? If so, do we need another crossover cable or is an ethernet cable fine? Do we hook up to the router or driver station?
Thanks...
Unread 31-12-2008, 00:26
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
The setup that you would use to view it wireless is to get the image from the cRio. If you make a new dashboard project in LabView and type in the correct IP address for the robot, you should be able to see your video feed. I was able to see it for the first time today! It's a little blurry but I'm guessing there's a way to adjust the focus.
You also may have to make a new project in labview, point the correct cRio IP and go to "Tools" and then do "Set up AXIS Camera"
Are you able to deploy projects to the cRio? Is everything else set up correctly?
Unread 31-12-2008, 00:42
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
In LabView, if you use one of the default examples that ships with the cRio, it is easy to add a front-panel element to get a live preview of the camera while developing code. Right click one of the wires in the code diagram that carries an image, and select "Add Indicator". This will add a front panel element that will show you the video in semi-live mode - there is a few seconds of delay from the wireless transmission and all.
Unread 03-01-2009, 20:04
legotech25's Avatar
legotech25 legotech25 is offline
Sarah
AKA: Sarah
FRC #1714 (TMCRC)
legotech25 will become famous soon enoughlegotech25 will become famous soon enough
Send a message via AIM to legotech25 Send a message via Yahoo to legotech25
I keep hearing that the LabView Dashboard is usable when WindRiver is used to program the cRio. Does anyone know how this setup works?
Team Captain - More Robotics 1714
2009 Milwaukee - Chairman's Award
2008 Milwaukee - Chariman's Award
2007 Cleveland - Kliener Perkens Buyers Caufield Entrepenureship, Engineering Insparation
2007 Milwaukee - Kliener Perkens Buyers Caufield Entrepeneurship, Website, Motorola Quality Underwriters Laboratory Safety
2006 Atlanta - Rookie Inspiration
2006 Cleveland - Rookie All-Star, Safety Runner-up
2006 Milwaukee - Rookie All-Star, Safety Runner-up
pi = 3.141592653589793238462643383279502884197169399715 10 ^_^
Unread 03-01-2009, 20:08
The laptop running the dashboard must have a static IP of 10.x.y.6. The data is automatically streamed to this IP address, and no other. Make sure you've set that up properly, or else the LabView Dashboard won't get any data.
New Video Blog Entry: "Video from Live LabVIEW Session for FRC Competitors in Toronto LVMastery NI LabVIEW 0 13-12-2008 08:09
WATCH LIVE FEED FROM OUR MEETING Raikon General Forum 9 05-02-2008 22:18
Does anyone know where to get a 9" interdiameter PVC? cvhsrobotics Chit-Chat 2 21-09-2004 01:14
Anyone know where I can get a sample.. Jason_384 General Forum 4 30-01-2002 23:04
