Go to Post FIRST doesnt care about the weather, and we still need a working robot. - Mike Heinowski [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Unread 14-12-2008, 20:57
Re: HDPE or ICE FLOOR
Originally Posted by gorrilla View Post
the conveyor belts they make are for moving bags around an airport, they are a like tiny little plastic plates with rubber tread on them, were you thinking like timing belt kinda thing?
Traction is directly related to frictional force. Force = mu * N, where mu is the coefficient of friction and N is the normal force (force directed directly away from a surface that something with friction is on). Notice the lack of area in that equation? Yep, there's a reason for that. Namely, surface area doesn't matter.
There's been discussion of this issue already, some years ago. Look it up.
And, the only way to increase mu is to increase the coefficient of friction. You can a) change materials or b) dig one material into the other. If you try doing b) to an HDPE section of the field, I'll call a rules violation, assuming there is a "no damaging the field" rule again.
Ice Ice Baby! Ian Curtis NASA Discussion 2 20-06-2008 00:15
UnEven Floor??? sgsdragons Technical Discussion 18 23-01-2006 18:52
Static on the HDPE Al Skierkiewicz Technical Discussion 60 12-03-2003 17:52
Hdpe Tempest Kit & Additional Hardware 1 02-02-2003 17:47
Friction Between Bins & HDPE Gary Bonner Technical Discussion 2 14-01-2003 08:56
