Re: 2009 Regional Webcasts
It is possible to record a webcast depending on how it is streamed. Any stream that can be opened in VLC can be recorded as it is being viewed. Typically it is much easier to archive the matches on-site however, and the archived footage is usually higher resolution than what is streamed.
I will also tentatively volunteer to parse matches depending on my schedule. The time to parse should not be an obstacle to people recording regionals, if you could record the whole regional but are hung up on separating the matches, somebody else with the time can probably do it.
My team is most likely going to be streaming and archiving the Minnesota North Star Regional and we are trying to figure out if we have the equipment/manpower to get something running for 10,000 Lakes as well. I'll post back and add myself to the list when things are certain.
