Go to Post you must do whats best for the company...not yourself. - Greg Perkins [more]
Unread 15-12-2008, 17:41
dtengineering's Avatar
AKA: Jason Brett
Re: Aluminum sprockets for drive train - several questions
We had some aluminum sprockets custom-cut from 1/8" plate using a waterjet cutter for the "aim high" game. We had a six wheel drive train (4x6" IFI traction wheels, 2x6" AM omnis) powered by four CIMs using the KOP transmission. We got into several pushing battles in Portland and at GTR, did a fair bit of ramp climbing, and basically slammed that poor little robot around pretty hard.
Although we broke lots of stuff on it and have put more "miles" on it as a demo robot than we have on any other machine, the sprockets are just fine.
Had we used steel we would have been in trouble... we weighed in for the eliminations at GTR weighing 120.0.
Jason
Unread 15-12-2008, 17:46
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Just for perspective....the blower (supercharger) drive on my 55 chevy uses aluminum pulleys with a 1/2" pitch toothed belt, 3" wide. I've worn out two sets of plain pulleys, each lasted about 20k miles. The last time, I paid extra for anodized pulleys, they're still doing fine after about 15k miles, no noticeable wear.
How many miles do you put on your robot?
Unread 15-12-2008, 17:54
AdamHeard's Avatar
Lead Mentor
I've worked on several drivetrains based on AndyMark's plate sprockets (both #25 and #35). So far have never had an issue with wear or failure. If you run the numbers, the size of the sprockets in a usual dead axle drive and the usual torques in such a drive show they are plenty fine; and if they aren't, just bump up to a larger sprocket until they are. I love them so much that all dead axle drives I work with are designed to specifically interface with the plate sprockets stock.
We've only had one issue, and that was a set of #25 with slightly misshaped teeth (Andy said because of feedrates). We mentioned it, and they were very promptly replaced.
Unread 15-12-2008, 19:03
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
Triple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant future
233 has used #25 chain on our drive wheels for 10 years with no wear problems. They were manufactured from 6061 aluminum with no anodizing. Our robot from 2003 still runs and has the original sprockets. Before we went to direct drive we used steel sprockets on the output shaft for strength of the shaft/sprocket interface.
mike d
See Ya
Unread 15-12-2008, 20:20
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Thanks to some of the added capabilities of the new control system, we are planning to include an odometer in our code. That way we can track repairs etc. by distance traveled and figure out how many tires we will need this year.
Of course, figuring out just what the milage really is is complicated somewhat by our tendencey to spend much of the time driving backwards.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 15-12-2008, 20:26
MrForbes's Avatar
AKA: Jim
I guess you need to ignore the direction signal from the encoders when incrementing to the odometer?
Very neat idea! I wonder what other stuff might be useful to keep track of?
Unread 16-12-2008, 09:42
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Everyone,
Thank you all very much for your testimonials--it's very helpful to know so many quality teams have used them successfully.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 16-12-2008, 10:34
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Chain shouldn't tear up the gears, but if you have something other than a drive train (ie: something that will include a huge load on it - arm, or other such load) your gears could get their teeth torn up...
We made a gear box my first year in FIRST (2001) and by the end of the season, the welds we used to attach the gear to the shaft help up awesome... but left the teeth the weak point, & it resulted in a half-moon shape gear. (The application was just a gear on gear mesh without using any chain & we were lifting full size robots & the goal that year which was about 150 lbs as well, all while putting that gearbox to it's full potential, & obviously past it's limit.)
Would have worked great as a cam, but unfortunately that wasn't our intended application of course.
We have since learned quite a bit about drive trains, & gearboxes & don't have that problem any more. (knock on wood).
Unread 16-12-2008, 13:34
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
We've used AndyMark and IFI sprockets for years, with both 25 and 35 chain, and the only real slip we’ve encountered came when the robot took a hit, bent a frame and introduced slack. So the two important lessons are A) have a tensioner system (with lots of room for movement), and B) the tendency to slip is directly proportional to the number of degrees of wrap that the chain makes around the sprockets. Make lots of >150 degree turns and you should be fine.
"It's NOT Just A Robot Thing!"
Unread 16-12-2008, 15:14
AdamHeard's Avatar
Lead Mentor
Are you referring to gears or sprockets? I can't really determine from what you're saying.
Somewhat related;
I have used 60T #35 Aluminum sprockets on extremely high powered and high reduction arms (As in the final stage of a 2500:1 reduction directly attached to about a 5' arm that was rather heavy [forgot specifics] and held the trackball at the end of that. It also hit the rack when extended at drive speed many times) with no signs of fatigue or tooth wear. I believe this is true of 330 as well.
Unread 16-12-2008, 15:53
True. 330's are custom-made; I don't know the metal. See also 330 2005 and 2007.
We also used some mid-size ones in 2007 for deploying ramps. Those took everything we threw at them and still worked. They were on the outside rear of the robot, virtually unshielded, IIRC.
Aluminum sprockets are a good thing if you use them correctly, in any application. The trick is to use them correctly. (I know 330 has used them in drivetrains and arms for some time. Other things, like tires, have or worn, but not the sprockets.)
Drive Train Components: the inner working parts of a drive train naruto137 Technical Discussion 3 10-12-2008 21:14
Need for Aluminum Gears and Sprockets? R.C. Technical Discussion 40 08-12-2008 15:32
Drive Train Questions Ryank Technical Discussion 3 16-01-2008 11:07
Questions on Mecanum Drive Train charmed862 General Forum 3 09-01-2008 22:23
Drive Train Size for Ramp Gratz Technical Discussion 8 26-01-2007 18:57
