Go to Post I think it's great the way people involved in FIRST always try so hard not to argue. It's a good sign that all the talk of Gracious Professionalism is working. - BaldwinNYRookie [more]
Unread 09-12-2008, 01:37
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
Anyone install windriver on linux yet?
I was just wondering if anyone has successfully installed WindRiver on a Linux machine yet?
My team hasn't gotten our software yet, as we just paid right before the deadline. I am particular interested in it successfully being installed on Debian based systems, however any Linux success is relevant too. Please post any failures, confusion, and especially success stories.
also I've heard there is a version of labview that runs on linux now, anyone using that?
-Andrew
(keen101)
Unread 09-12-2008, 02:46
bagawk bagawk is offline
AKA: LeeP
FRC #0997 (Spartan Robotics)
bagawk is an unknown quantity at this point
Re: Anyone install windriver on linux yet?
I have it installed with ubuntu as host OS. It is not "supported" but seems to be fine. My team has not received the kit yet, but will see how it goes then.
Before I installed windriver workbench, I looked into building a GNU toolchain. Unfortunately I was not able to get gcc to completely build.
For those that want to continue on that route, you will need to download headers for vxworks. National instrument provides this for vxworks 6.1 and 6.3 (no idea what is on the controller we get from first). http://zone.ni.com/devzone/cda/tut/p/id/5694
You can build binutils with the target powerpc-wrs-vxworks just fine. Trying to build gcc I had major issues relating to the headers.
Another alternative would be to use the compiler provided in workbench and create some makefiles. Not my preferred route, but it should work okay.
Unread 09-12-2008, 14:44
I'm not quite following what you did, and I consider myself pretty proficient with Linux. What do you mean by "host OS"? Normally when people use the term "host OS", they are talking about virtual machines,.and generally also use the term "guest OS" to describe what the "host OS" is hosting.
As for me, as soon as I get my hands on the compiler suite, I am going to first install it under WINE and play with it that way. After I get it working under Wine with Makefiles, I'll see about running it naively if performance is actually a problem. No sense in spending a couple of days in order to shave 1 second off compile time. Does anyone know much about how the Debugger works? If it uses standard gdb network protocols, we might be able to just use gdb or one of it's graphical interfaces like ddd to be able to debug code under Linux.
Along those lines, does anyone know where to get the compiler suite besides from the kit?
Unread 09-12-2008, 15:12
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
I believe he was referring to cross-compiling which uses the terms host architecture (probably i686-pc-linux-gnu or x86_64-pc-linux-gnu) and target architecture (I think it is PPC603gnu now).
I was only able to get it using the CD or by downloading their evaluation product. It may be based on GCC but AKAIK it is not free.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 11-12-2008, 05:58
keen101's Avatar
Ubuntu Linux User
Cool. I'm anxious to hear more success stories with Linux and windriver. I don't think it will work very well under WINE, but that's my opinion.
on another note... i successfully got Labview to work on Ubuntu Linux. The price is pretty steep, so most teams won't be able to afford it. Our team really can't afford it either if you want to know the truth. Anyway, the hardest part was converting the .RPM packages to .DEB files, but i sucessfully did it with "alien".
feel free to email me with specific questions regarding Labview under Ubuntu. I can even try to help look for some sort of discounts if you are really drooling to get labview working under ubuntu. It is much faster under linux.
Unread 11-12-2008, 13:44
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
It would be great if you could write up a HOWTO with specific instructions. Did you end up buying the commercial version of LabView? That's what it sounds like from your price comment. Do you have all of the FIRST-specific VIs working?
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 15-12-2008, 17:56
keen101's Avatar
Ubuntu Linux User
Yeah, I'd be happy to write a how-to once i get the official FRC version on LabVIEW for Linux. To answer the question about the money, we were seriously considering buying the commercial version (maybe not I'll never know really, maybe it was just a fools dream), I was running a trial version of Labview for Linux and had got that running on Ubuntu.
But, i found this today so we will request it.
http://www.chiefdelphi.com/forums/sh...56&postcount=9
I haven't tried any of the Vi's yet, and if NI hadn't been willing to ship Linux versions by request, I'd probably have never been able to manage getting everything to work. As i understand it many things are different in the FRC version, especially the Real-Time module and some other drivers.
Unread 15-12-2008, 23:30
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
Also, no matter what operating system you're running, they're having issues with a bug in the FRC version that modifies a file shared between all LabView installations on the machine incorrectly, therefore resulting in data that's unusable by all installations. Uninstall all other installations BEFORE you install the FRC version.
Sweet, I definitely need to look into getting one of them Linux installer CD's. I'm so glad NI is so cross-platform with everything, it makes everybody love them more!
Also, where did you get the evaluation version of LabView for Linux? I haven't been able to find one anywhere.
Unread 16-12-2008, 01:51
keen101's Avatar
Ubuntu Linux User
To be honest, i can't seem to find it again...
I went back to one page i thought i had been on, but can only find the windows trial version. Weird. I don't know, i was doing a lot of googling at the time, and was trying to find anything that had to do with labview and linux. Oh, well. It doesn't matter anyway i suppose.
Does anyone know how to obtain the Linux version of WindRiver? Is it included on the software DVD? Or do we have to request it from FRC team support?
Unread 17-12-2008, 20:34
pogenwurst pogenwurst is offline
Ubuntu User
AKA: Brian
FRC #2007 (Robots of the Round Table)
pogenwurst is on a distinguished road
Send a message via AIM to pogenwurst
It's not on the software DVD.
Though there is a native Linux version of LabVIEW, if I've understood the situation correctly, in order to program for a CompactRIO target you need to have the LabVIEW Real-time Module, which is Windows-only.
Unread 17-12-2008, 22:28
Ubuntu User
AKA: Brian
I just spent some time fiddling with it, and it's of note that the redistributable compiler for VxWorks 6.3 (mentioned further up) runs and successfully compiles the example code that comes in the zip provided that you set the proper environment variables in the Wine registry.
The following is a modified version of the Makefile from the example code that allows it to be built through Eclipse on Linux:
# edit these as needed to fit your setup
WIND_BASE = "c:\gccdist\WindRiver\vxworks-6.3"
WINECMD = wine
# These variables control the compiler and linker flags. Change them as
# appropriate.
DEBUG_MODE = 0
ADDED_CFLAGS =
ifeq ($(DEBUG_MODE),1)
OBJ_DIR := PPC603gnu_DEBUG
CFLAGS = -g -mlongcall
else
CFLAGS = -Os -fstrength-reduce -fno-builtin -fno-strict-aliasing -mlongcall
endif
LINKFLAGS = $(CFLAGS)
LIBPATH =
# List all the *compiled* object files here, under the OBJ_DIR
# directory. Make will automatically locate the source file and
# compile it.
OBJECTS := $(OBJ_DIR)/example.o
# This is the name of the output shared library.
PROJECT_TARGETS := $(OBJ_DIR)/example.out
# If you have other VxWorks .a files to reference, list them here.
LIBS =
LIBPATH =
# Everything after this line should not need to be modified for
# basic compilation. However, significant changes to the build structure
# will probably involve modifying these lines.
CPU = PPC603
TOOL_FAMILY = gnu
TOOL = gnu
CC_ARCH_SPEC = -mcpu=603 -mstrict-align -mno-implicit-fp
IDE_INCLUDES = -I$(WIND_BASE)/target/h -I$(WIND_BASE)/target/h/wrn/coreip
# This basic rule compiles a .c file into a .o file. It can be adapted to
# all other source files that gcc can compile, including assembly (.s) and
# C++ (.cpp, .cc, .C, .cxx) files. To enable support for those extensions,
# copy this rule and modify its extension and compile flags for the
# required source file type.
$(OBJ_DIR)/%.o : %.c
	$(WINECMD) ccppc $(CFLAGS) $(CC_ARCH_SPEC) -ansi  -Wall  -MD -MP $(ADDED_CFLAGS) $(IDE_INCLUDES) $(ADDED_INCLUDES) -DCPU=$(CPU) -DTOOL_FAMILY=$(TOOL_FAMILY) -DTOOL=$(TOOL) -D_WRS_KERNEL   $(DEFINES) -o "$@" -c "$<"
# Adapted rule for .cpp files
$(OBJ_DIR)/%.o : %.cpp
	$(WINECMD) c++ppc $(CFLAGS) $(CC_ARCH_SPEC) -ansi  -Wall  -MD -MP $(ADDED_CFLAGS) $(IDE_INCLUDES) $(ADDED_INCLUDES) -DCPU=$(CPU) -DTOOL_FAMILY=$(TOOL_FAMILY) -DTOOL=$(TOOL) -D_WRS_KERNEL   $(DEFINES) -o "$@" -c "$<"
all : check_objectdir $(PROJECT_TARGETS)
$(PROJECT_TARGETS) : $(OBJECTS)
	rm -f "$@" ctdt.c;$(WINECMD) nmppc $(OBJECTS) | $(WINECMD) tclsh $(WIND_BASE)/host/resource/hutils/tcl/munch.tcl -c ppc > ctdt.c
	$(WINECMD) ccppc $(LINKFLAGS) $(CC_ARCH_SPEC) -fdollars-in-identifiers -Wall $(ADDED_CFLAGS) $(IDE_INCLUDES) $(ADDED_INCLUDES) -DCPU=$(CPU) -DTOOL_FAMILY=$(TOOL_FAMILY) -DTOOL=$(TOOL) -D_WRS_KERNEL   $(DEFINES)  -o ctdt.o -c ctdt.c
	$(WINECMD) ccppc -r -nostdlib -Wl,-X -T $(WIND_BASE)/target/h/tool/gnu/ldscripts/link.OUT -o "$@" $(OBJECTS) $(LIBPATH) $(LIBS)  $(ADDED_LIBPATH) $(ADDED_LIBS) ctdt.o
	rm -f ctdt.c ctdt.o
check_objectdir :
	@if [ ! -d "$(OBJ_DIR)" ]; then\
		mkdir -p $(OBJ_DIR);\
	fi
clean :
	rm -f $(OBJECTS) $(PROJECT_TARGETS) $(wildcard $(OBJ_DIR)/*.unstripped)
.DUMMY: check_objectdir clean
Again, this is the example code that comes with the redistributable compiler, not any WPILib code. I imagine it can be made to work with that too, but I haven't tried yet.
I'll post back as I make progress.
Unread 18-12-2008, 02:54
keen101's Avatar
Ubuntu Linux User
Well, just requested a linux version of LabVIEW. Hopefully NI will send it....
cool. That would be ok, if you could get it to compile from Eclipse. I already have Eclipse installed. I've heard WindRiver is basically a modified Eclipse. If you could get it to work with Eclipse, then that should work. Keep me informed on any progress you make.
Thanks. I didn't think it would be. I am going on a limb here, and gonna say that maybe we can get the Linux version of WindRiver by requesting it from frc team suport? I could be wrong. Maybe they haven't even perfected the Linux version yet. I really don't know. I can't seem to find documentation about it anywhere...
no, I'm pretty sure the real-time module is included with the linux version too.
If I made any comments about the Real-time module, it was that i am pretty sure the Real-time module on an everyday version of labview is very different from the FRC version. I think it's different because our cRIO's aren's standard cRIO's, they are custom built ones.
Unread 18-12-2008, 08:44
Ubuntu User
AKA: Brian
http://digital.natinst.com/public.nsf/$CXIV/ATTACH-AEEE-7AVNNM/$FILE/readme_RT.html
Supported Platforms
The LabVIEW Real-Time Module supports Windows 2000/XP and Windows Vista (32-bit and 64-bit). The LabVIEW Real-Time Module does not support Windows NT/Me/9x.
http://www.ni.com/labview/requirements
LabVIEW Development System for Windows requirements plus:
200 MB additional available disk space
Apparently version 7.1 runs on Linux. That's no help, though.
Unread 18-12-2008, 12:30
keen101's Avatar
Ubuntu Linux User
The links you provided don't prove anything. Most of the documentation from ni is for windows anyway. that doesn't mean mac and Linux versions don't exist.
i remember seeing a real time module .rpm file with the linux tutorial. I could email it to you if you want to look at it. (if i still have it)
But, i have the feeling you just feel like arguing.
Unread 18-12-2008, 14:32
Ubuntu User
AKA: Brian
I only intended to save you and others time.
I suspect that the RPM you're referring to is labview85-rte-8.5.1-1.i386.rpm. Unless I'm terribly mistaken RTE in this case stands for the LabVIEW Run Time Engine, which is used to deploy VIs on computers that don't have the full development system installed.
In any case, I will say no more, and wish you the best of luck with your search.
Trouble booting Linux from hard drive after CD install edomus Technical Discussion 2 01-11-2004 08:03
Anyone registered yet? Gary Dillard General Forum 54 20-10-2004 01:22
anyone know how to install gallery on a webserver? Greg Needel Website Design/Showcase 5 19-08-2004 14:40
anyone at epcot yet? Jgreenwd1 Chit-Chat 3 24-04-2002 18:26
