Re: Anyone install windriver on linux yet?
I went back to one page i thought i had been on, but can only find the windows trial version. Weird. I don't know, i was doing a lot of googling at the time, and was trying to find anything that had to do with labview and linux. Oh, well. It doesn't matter anyway i suppose. Does anyone know how to obtain the Linux version of WindRiver? Is it included on the software DVD? Or do we have to request it from FRC team support? |
Though there is a native Linux version of LabVIEW, if I've understood the situation correctly, in order to program for a CompactRIO target you need to have the LabVIEW Real-time Module, which is Windows-only. |
I just spent some time fiddling with it, and it's of note that the redistributable compiler for VxWorks 6.3 (mentioned further up) runs and successfully compiles the example code that comes in the zip provided that you set the proper environment variables in the Wine registry.
The following is a modified version of the Makefile from the example code that allows it to be built through Eclipse on Linux: Code:
# edit these as needed to fit your setup WIND_BASE = "c:\gccdist\WindRiver\vxworks-6.3" WINECMD = wine # These variables control the compiler and linker flags. Change them as # appropriate. DEBUG_MODE = 0 ADDED_CFLAGS = ifeq ($(DEBUG_MODE),1) OBJ_DIR := PPC603gnu_DEBUG CFLAGS = -g -mlongcall else OBJ_DIR := PPC603gnu CFLAGS = -Os -fstrength-reduce -fno-builtin -fno-strict-aliasing -mlongcall endif LINKFLAGS = $(CFLAGS) LIBPATH = # List all the *compiled* object files here, under the OBJ_DIR # directory. Make will automatically locate the source file and # compile it. OBJECTS := $(OBJ_DIR)/example.o # This is the name of the output shared library. PROJECT_TARGETS := $(OBJ_DIR)/example.out # If you have other VxWorks .a files to reference, list them here. LIBS = LIBPATH = # Everything after this line should not need to be modified for # basic compilation. However, significant changes to the build structure # will probably involve modifying these lines. CPU = PPC603 TOOL_FAMILY = gnu TOOL = gnu CC_ARCH_SPEC = -mcpu=603 -mstrict-align -mno-implicit-fp IDE_INCLUDES = -I$(WIND_BASE)/target/h -I$(WIND_BASE)/target/h/wrn/coreip # This basic rule compiles a .c file into a .o file. It can be adapted to # all other source files that gcc can compile, including assembly (.s) and # C++ (.cpp, .cc, .C, .cxx) files. To enable support for those extensions, # copy this rule and modify its extension and compile flags for the # required source file type. $(OBJ_DIR)/%.o : %.c $(WINECMD) ccppc $(CFLAGS) $(CC_ARCH_SPEC) -ansi -Wall -MD -MP $(ADDED_CFLAGS) $(IDE_INCLUDES) $(ADDED_INCLUDES) -DCPU=$(CPU) -DTOOL_FAMILY=$(TOOL_FAMILY) -DTOOL=$(TOOL) -D_WRS_KERNEL $(DEFINES) -o "$@" -c "$<" # Adapted rule for .cpp files $(OBJ_DIR)/%.o : %.cpp $(WINECMD) c++ppc $(CFLAGS) $(CC_ARCH_SPEC) -ansi -Wall -MD -MP $(ADDED_CFLAGS) $(IDE_INCLUDES) $(ADDED_INCLUDES) -DCPU=$(CPU) -DTOOL_FAMILY=$(TOOL_FAMILY) -DTOOL=$(TOOL) -D_WRS_KERNEL $(DEFINES) -o "$@" -c "$<" all : check_objectdir $(PROJECT_TARGETS) $(PROJECT_TARGETS) : $(OBJECTS) rm -f "$@" ctdt.c;$(WINECMD) nmppc $(OBJECTS) | $(WINECMD) tclsh $(WIND_BASE)/host/resource/hutils/tcl/munch.tcl -c ppc > ctdt.c $(WINECMD) ccppc $(LINKFLAGS) $(CC_ARCH_SPEC) -fdollars-in-identifiers -Wall $(ADDED_CFLAGS) $(IDE_INCLUDES) $(ADDED_INCLUDES) -DCPU=$(CPU) -DTOOL_FAMILY=$(TOOL_FAMILY) -DTOOL=$(TOOL) -D_WRS_KERNEL $(DEFINES) -o ctdt.o -c ctdt.c $(WINECMD) ccppc -r -nostdlib -Wl,-X -T $(WIND_BASE)/target/h/tool/gnu/ldscripts/link.OUT -o "$@" $(OBJECTS) $(LIBPATH) $(LIBS) $(ADDED_LIBPATH) $(ADDED_LIBS) ctdt.o rm -f ctdt.c ctdt.o check_objectdir : @if [ ! -d "$(OBJ_DIR)" ]; then\ mkdir -p $(OBJ_DIR);\ fi clean : rm -f $(OBJECTS) $(PROJECT_TARGETS) $(wildcard $(OBJ_DIR)/*.unstripped) .DUMMY: check_objectdir clean I'll post back as I make progress. |
Well, just requested a linux version of LabVIEW. Hopefully NI will send it....
Keep me informed on any progress you make.Quote:
If I made any comments about the Real-time module, it was that i am pretty sure the Real-time module on an everyday version of labview is very different from the FRC version. I think it's different because our cRIO's aren's standard cRIO's, they are custom built ones. |
The links you provided don't prove anything. Most of the documentation from ni is for windows anyway. that doesn't mean mac and Linux versions don't exist.
i remember seeing a real time module .rpm file with the linux tutorial. I could email it to you if you want to look at it. (if i still have it) But, i have the feeling you just feel like arguing. |
#7
I suspect that the RPM you're referring to is labview85-rte-8.5.1-1.i386.rpm. Unless I'm terribly mistaken RTE in this case stands for the LabVIEW Run Time Engine, which is used to deploy VIs on computers that don't have the full development system installed. In any case, I will say no more, and wish you the best of luck with your search. |
#8
In either case i am going to assume to FRC version of LabVIEW for Linux is capable of programming the FRC nRIO just like the windows version. I'm going to assume they have included everything that would be needed. Last edited by keen101 : 18-12-2008 at 23:42. |
#9
This seems strange to me, there shouldn't really be an issue with realtime programming in Linux, there are entire realtime kernels out there (2 of my computers use them). Anybody know what the realtime module does that the regular LabView version doesn't?
#11
The realtime module implements the client protocol, the cross compiler, and integrates all of the configuration stuff for discovering the chassis, downloading, etc.
It isn't that these things can't be done with linux. They certainly can. Years ago there was an RT version for Mac OSX. But demand for the Mac and also for linux versions of RT seem to be low. With a product this complex, even testing on an OS adds up to significant time. So if there isn't apparent demand, it gets trimmed. Many of the developers at NI are linux fans and it isn't personal, it just comes down to supplying products that the majority of engineers need. Greg McKaskle |
#12
I just succeeded in compiling and deploying code under Linux to the cRIO! I used wine to run the compiler and wput to upload it. I am going to write up a document on this in a bit and post it. I had to copy over the license file from Windows to get it working under Linux, so I'm not sure how that is going to work for people who don't install it under Windows first.
Off to work on getting the debugger working... |
| Trouble booting Linux from hard drive after CD install | edomus | Technical Discussion | 2 | 01-11-2004 08:03 |
| Anyone registered yet? | Gary Dillard | General Forum | 54 | 20-10-2004 01:22 |
| anyone know how to install gallery on a webserver? | Greg Needel | Website Design/Showcase | 5 | 19-08-2004 14:40 |
| anyone at epcot yet? | Jgreenwd1 | Chit-Chat | 3 | 24-04-2002 18:26 |
