Go to Post OMG are you saying we are going to have a question mark game element next, that would be crazy - Greg Needel [more]
Unread 16-12-2008, 13:34
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
Re: Aluminum sprockets for drive train - several questions
We've used AndyMark and IFI sprockets for years, with both 25 and 35 chain, and the only real slip we’ve encountered came when the robot took a hit, bent a frame and introduced slack. So the two important lessons are A) have a tensioner system (with lots of room for movement), and B) the tendency to slip is directly proportional to the number of degrees of wrap that the chain makes around the sprockets. Make lots of >150 degree turns and you should be fine.
"It's NOT Just A Robot Thing!"
Drive Train Components: the inner working parts of a drive train naruto137 Technical Discussion 3 10-12-2008 21:14
Need for Aluminum Gears and Sprockets? R.C. Technical Discussion 40 08-12-2008 15:32
Drive Train Questions Ryank Technical Discussion 3 16-01-2008 11:07
Questions on Mecanum Drive Train charmed862 General Forum 3 09-01-2008 22:23
Drive Train Size for Ramp Gratz Technical Discussion 8 26-01-2007 18:57
