Go to Post You can't observe things that aren't seen or reported. - Andrew Schreiber [more]
Unread 16-12-2008, 15:24
mole mole is offline
AKA: Anmol Dhar
FRC #0772 (SabreBytes)
mole is an unknown quantity at this point
Re: New Power Distribution/ Fuse Pannel Problem
Perhaps I can clairfy.
The battery voltage is 12 volts from the mains, going into the PD board. When you put the fuse in, the output from the terminal is 12 volts. However, when the fuse is removed, the output is STILL 12 volts.
It sounds to me like the board may indeed be faulty, as the output should be ZERO (I would think) after the fuse is removed. Otherwise, what is the purpose of a fuse if current/voltage is still allowed to pass through.
New Power Distribution jsmith234 Electrical 6 03-02-2007 15:05
Power distribution Block? Pontchartrain Electrical 3 27-01-2006 07:30
Power Distribution Requirements kham Electrical 2 14-01-2006 12:35
Power Distribution xxmaddjxx Electrical 13 30-01-2005 00:43
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
