Go to Post ah, common sense, not as common as one might think... - Ansem Retort [more]
Unread 16-12-2008, 15:14
AdamHeard's Avatar
Lead Mentor
Re: Aluminum sprockets for drive train - several questions
Originally Posted by Elgin Clock View Post
Chain shouldn't tear up the gears, but if you have something other than a drive train (ie: something that will include a huge load on it - arm, or other such load) your gears could get their teeth torn up...
We made a gear box my first year in FIRST (2001) and by the end of the season, the welds we used to attach the gear to the shaft help up awesome... but left the teeth the weak point, & it resulted in a half-moon shape gear. (The application was just a gear on gear mesh without using any chain & we were lifting full size robots & the goal that year which was about 150 lbs as well, all while putting that gearbox to it's full potential, & obviously past it's limit.)
Would have worked great as a cam, but unfortunately that wasn't our intended application of course.
We have since learned quite a bit about drive trains, & gearboxes & don't have that problem any more. (knock on wood).
Are you referring to gears or sprockets? I can't really determine from what you're saying.
Somewhat related;
I have used 60T #35 Aluminum sprockets on extremely high powered and high reduction arms (As in the final stage of a 2500:1 reduction directly attached to about a 5' arm that was rather heavy [forgot specifics] and held the trackball at the end of that. It also hit the rack when extended at drive speed many times) with no signs of fatigue or tooth wear. I believe this is true of 330 as well.
Unread 16-12-2008, 15:53
True. 330's are custom-made; I don't know the metal. See also 330 2005 and 2007.
We also used some mid-size ones in 2007 for deploying ramps. Those took everything we threw at them and still worked. They were on the outside rear of the robot, virtually unshielded, IIRC.
Aluminum sprockets are a good thing if you use them correctly, in any application. The trick is to use them correctly. (I know 330 has used them in drivetrains and arms for some time. Other things, like tires, have or worn, but not the sprockets.)
Drive Train Components: the inner working parts of a drive train naruto137 Technical Discussion 3 10-12-2008 21:14
Need for Aluminum Gears and Sprockets? R.C. Technical Discussion 40 08-12-2008 15:32
Drive Train Questions Ryank Technical Discussion 3 16-01-2008 11:07
Questions on Mecanum Drive Train charmed862 General Forum 3 09-01-2008 22:23
Drive Train Size for Ramp Gratz Technical Discussion 8 26-01-2007 18:57
