Go to Post FIRST is not about a robot competition . . there just happens to be one at every FIRST event. - Stuart [more]
Unread 16-12-2008, 12:41
Joining the 900 Meme Team
FRC #0079
Re: pic: VEX High Reduction Gearbox
Originally Posted by squirrel View Post
If not for that pesky friction....
Also inertia
Someone please correct me if I am wrong but wouldn't you be fighting a force of 1/12(mass)(3*radius^2 + height^2) * 244140625 Newtons to get it started? Now, maybe if you put a crazy long lever arm on the small wheel's shaft you could over come that.
Of course, even that number is almost nothing compared to the real number because you would have to account for starting the gears rotating too. This could be an interesting problem for more advanced students, What is the max length of a lever arm you could attach a 100 kg weight to and still not have the large wheel move? Have them run it both ways.
But very cool John.
Last edited by Andrew Schreiber : 16-12-2008 at 12:42. Reason: My sentence structure was bad.
Unread 16-12-2008, 17:55
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
What I want to know is what the backlash is at the input gear. It has to be several thousand full revolutions of the input shaft. Which amuses me to no end, given I'm usually working with gearheads that measure backlash in minutes of arc....
Unread 16-12-2008, 18:04
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
Now try replacing all those medium gears with the large gears.
Unread 16-12-2008, 18:10
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Cool gearbox, JVN!
We had a guy call us this past summer, wanting to use a Toughbox and a low power motor to slowly move a parabolic solar panel so that it follows the sun.
So... we found a small gearmotor package from Dayton, and used that as an input to the Toughbox. We bench tested this assembly and found out that the output shaft of the Toughbox was doing 1 revolution in about 18 minutes. Of course, this is much faster than the Earth is spinning, but it was a good way to use a very low power motor to move a 12 foot long solar panel.
AB
Unread 16-12-2008, 22:41
Rupnick's Avatar
Rupnick Rupnick is offline
FRC #1675 (UPS - Ultimate Protection Squad)
Rupnick is on a distinguished road
Send a message via AIM to Rupnick
Now lest see you "back-drive" that!
Brown is the New Gold
Unread 17-12-2008, 02:14
Bannanakin's Avatar
Bannanakin Bannanakin is offline
FRC #0604 (Quixilver)
Bannanakin is just really niceBannanakin is just really niceBannanakin is just really niceBannanakin is just really niceBannanakin is just really nice
Send a message via AIM to Bannanakin
Have you seen the mini jet engines that are in the fancy rc planes? Some of those spin up to around 150,000 rpm. At that rate it would take a little over a day to turn the wheel.
Eugene, I REALLY dont think its necessary to cad the cross bar accurate to the 9th decimal place when we are cutting it with a HACKSAW.....
Unread 17-12-2008, 06:38
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
It's going to move the large wheel if you apply any torque to the small wheel at all, the amount of torque just determines the acceleration, which will be tiny for any reasonable amount of mass. The only thing that might actually stop the entire thing from rotating is the friction in the bearings, which I don't think is very large.
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
Unread 17-12-2008, 08:43
FRC #0079
Thanks, you can tell it has been a while since physics.
Unread 17-12-2008, 16:36
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
That is, before the thing starts melting or grinds itself into pieces...
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 18-12-2008, 08:38
Libby K's Avatar
Libby K Libby K is offline
Always a MidKnight Inventor.
FRC #1923 (The MidKnight Inventors)
Rookie Year: 1992
Libby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond repute
Wow. This is just plain cool. =]
Libby Kamen
Team 1923: The MidKnight Inventors
2006-2009: Founder, Captain, Operator, Regional Champion.
2010-Always: Proud Alumni, Mentor & Drive Coach. 2015 Woodie Flowers Finalist Award.
229: Division By Zero / 4124: Integration by Parts
2010-2013: Clarkson University Mentor for FLL, FTC & FRC
FIRST Partner Associate, United Therapeutics
#TeamUnither | facebook, twitter & instagram | @unitherFIRST
questions? comments? concerns? | twitter: @libbyk | about.me/libbykamen
Unread 18-12-2008, 10:01
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Heh - very cool. If you could "drive" the big wheel from the Earth to the Moon (at apogee, the approximate distance is 251,968 miles), the little wheel would turn only 4.1629 times.
-dave
Unread 18-12-2008, 10:15
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
-dave
Say we're driving on the big wheel to Mars ... how many little wheel turns?
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 18-12-2008, 11:05
dlavery's Avatar
Curmudgeon
At closest approach (such as during the perihelic opposition in August 2003) the Earth-Mars distance can be as small at 34,646,418 miles. In that case, the little wheel turns 572.418 times. During conjunction, such as the one just ending this week, the distance can be approximately 247,821,000 miles. In that case, the little wheel turns 4094.437 times. I would find that number to be excessive, so for a Mars transportation application I would want to add on at least one more 12:60 reduction stage.
-dave
Unread 18-12-2008, 16:47
AdamHeard's Avatar
Lead Mentor
-dave
I would like to thank both John and Dave for finally making me understand how far away mars is
Unread 19-12-2008, 20:13
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
All I can say is - we are such geeks!
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
pic: vex aim high colin340 Extra Discussion 3 05-09-2006 22:59
pic: Vex 2-speed gearbox crazykid234 Extra Discussion 3 03-01-2006 20:18
Drill Motor Gearbox Reduction Ratios archiver 2000 3 23-06-2002 23:05
