Re: Can i still benchtest without OTB version?
benchtest for post update? sorry for the noob questions, but im slightly confused? what exactly do you mean by benchtest for post update?
The Pre-update bench test involves the use of jumpers to change from tank drive to arcade. after you do the update (hence the "post update") you re-run the test, but instead of jumpers, you switch between tank and arcade with the throttle control on joystick #1. Also, pre update you can't run auton. mode unless you switch to auton, and then power cycle the CS. After the update, you can go back and forth at will.
now the throttle control, is that the small thing with the tab, in the middle of the joystick towards the bottom where the base is? its default location is down, but u can move it up? is that the throttle control?
There are three analog axes on the joystick, X and Y the joystick axes and the throttle. The throttle is the knob like thing on the base in the middle on the rear. Yes it has a tab. I don't consider it to have a "default" position since it is not spring biased, but when the tab is down, the analog output is minimum, and when the tab is up, the output is at its maximum.
ahhh.... i see, ok, thank you, i really appreciate it. Good Luck this year.
| Robot Disabled, yet I can still actuate a Cylinder- HELP! | purduephotog | Programming | 21 | 21-02-2007 16:55 |
| Can Victors work as ESCs without all of the other electronic components? | VEN | Electrical | 15 | 11-02-2007 18:52 |
| Can you have a FVC team without high school affiliation? | Bongle | FIRST Tech Challenge | 16 | 29-11-2006 08:31 |
| Can we still go? | Michael Corsetto | Championship Event | 1 | 22-03-2006 06:23 |
| Can first go this year without changing a rule | nuggetsyl | Rules/Strategy | 11 | 07-01-2005 15:36 |
