Go to Post Although I have much yet to go, in my short time in FIRST I have learned there is no such thing as a waste of time, especially when a) fundraising, b) mentoring students, or c) reading directions. - Amanda Morrison [more]
Unread 16-12-2008, 12:01
programmr's Avatar
programmr programmr is offline
AKA: Face
FRC #0522
programmr is a jewel in the roughprogrammr is a jewel in the roughprogrammr is a jewel in the rough
Send a message via AIM to programmr
Can i still benchtest without OTB version?
Hello, i updated the firmware on the driver station, but now i realized i didnt do the benchtest. Can i still benchtest with the updated firmware for the driver station? i tried hooking it up after installing the firmware update for the driver station, and under mode and system i get invalid.
"I would love to change the world but no one will give me the source code"
Unread 16-12-2008, 12:09
Re: Can i still benchtest without OTB version?
You can't continue with the original benchtest.
Practically speaking though, you can run your own benchtest, but the test description given no longer applies. You just want to confirm that moving the joystick in USB1 results in a motor in PWM01 at the other end moving.
However, the cRIO firmware also has to be upgrade to match the DS firmware upgrade before .
Unread 16-12-2008, 13:03
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Once you update the cRIO, you can run the bech test for post update. The real difference is that you don't have to use jumpers to switch between arcade and tank drive. The downside is, you don't get to test the digital inputs for functionality.
I would assume they were tested at the factory though, so you should be okay if the post update test works.
Former Mentor Team 1771
Former mentor Team 4509
Unread 16-12-2008, 20:17
programmr's Avatar
AKA: Face
FRC #0522
benchtest for post update? sorry for the noob questions, but im slightly confused? what exactly do you mean by benchtest for post update?
Unread 16-12-2008, 20:24
martin417's Avatar
AKA: Martin Wilson
The Pre-update bench test involves the use of jumpers to change from tank drive to arcade. after you do the update (hence the "post update") you re-run the test, but instead of jumpers, you switch between tank and arcade with the throttle control on joystick #1. Also, pre update you can't run auton. mode unless you switch to auton, and then power cycle the CS. After the update, you can go back and forth at will.
Unread 16-12-2008, 20:29
programmr's Avatar
AKA: Face
FRC #0522
now the throttle control, is that the small thing with the tab, in the middle of the joystick towards the bottom where the base is? its default location is down, but u can move it up? is that the throttle control?
Unread 16-12-2008, 20:37
martin417's Avatar
AKA: Martin Wilson
There are three analog axes on the joystick, X and Y the joystick axes and the throttle. The throttle is the knob like thing on the base in the middle on the rear. Yes it has a tab. I don't consider it to have a "default" position since it is not spring biased, but when the tab is down, the analog output is minimum, and when the tab is up, the output is at its maximum.
Unread 16-12-2008, 20:52
programmr's Avatar
AKA: Face
FRC #0522
ahhh.... i see, ok, thank you, i really appreciate it. Good Luck this year.
Robot Disabled, yet I can still actuate a Cylinder- HELP! purduephotog Programming 21 21-02-2007 16:55
Can Victors work as ESCs without all of the other electronic components? VEN Electrical 15 11-02-2007 18:52
Can you have a FVC team without high school affiliation? Bongle FIRST Tech Challenge 16 29-11-2006 08:31
Can we still go? Michael Corsetto Championship Event 1 22-03-2006 06:23
Can first go this year without changing a rule nuggetsyl Rules/Strategy 11 07-01-2005 15:36
