Re: Can i still benchtest without OTB version?
now the throttle control, is that the small thing with the tab, in the middle of the joystick towards the bottom where the base is? its default location is down, but u can move it up? is that the throttle control?
There are three analog axes on the joystick, X and Y the joystick axes and the throttle. The throttle is the knob like thing on the base in the middle on the rear. Yes it has a tab. I don't consider it to have a "default" position since it is not spring biased, but when the tab is down, the analog output is minimum, and when the tab is up, the output is at its maximum.
ahhh.... i see, ok, thank you, i really appreciate it. Good Luck this year.
| Robot Disabled, yet I can still actuate a Cylinder- HELP! | purduephotog | Programming | 21 | 21-02-2007 16:55 |
| Can Victors work as ESCs without all of the other electronic components? | VEN | Electrical | 15 | 11-02-2007 18:52 |
| Can you have a FVC team without high school affiliation? | Bongle | FIRST Tech Challenge | 16 | 29-11-2006 08:31 |
| Can we still go? | Michael Corsetto | Championship Event | 1 | 22-03-2006 06:23 |
| Can first go this year without changing a rule | nuggetsyl | Rules/Strategy | 11 | 07-01-2005 15:36 |
