Go to Post I have yet to see an error where disabling the watchdog was the correct decision. - EricVanWyk [more]
Unread 16-12-2008, 13:50
koreabell koreabell is offline
Team 956 Safety Captain
FRC #0956 (Eagles)
koreabell is an unknown quantity at this point
Joystick axis values in new controller
Are the values of joystick axis(x,y,and z) in new controller 0 to 255 like last controller? or do they have float value of -1.0 to +1.0?
i can't find what value it returns although my guess is float value of -1.0 to +1.0 since doxgen says function type is float.
just making sure
Unread 16-12-2008, 14:02
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Joystick axis values in new controller
READ the Programming Guide, your question will be answered.
Unread 16-12-2008, 14:47
FRC #0956 (Eagles)
well I'm programming in c++ and there is no examples or something like that on C/C++ Users Guide for joystick axis value(there's nothing except for big "DRAFT" across the page when you go to joystick page)
there is GetRawAxis() function under joystick class which i assume it will return values between 0 to 255, but that is also float type function while GetRaw() function under PWM class is int type(actually UINT8 type) function.
i know float can handle more wide range than int, thus GetRawAxis() might return values between 0 and 255, but still i'm not sure and i won't know until new controller comes
anyway, i wrote a function that will return values between 0 and 255 even if GetY() or GetAxis() function returns values between -1.0 and +1.0
Unread 16-12-2008, 17:05
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Refer to the C/C++ Programmer Reference Guide.
You can either use Joystick::GetRawAxis(UINT32 axis), where axis is a value between 1 and 6 specifying the axis, or you can simply use Joystick::GetX() and Joystick::GetY(). All of these functions return a floating point value between -1.0f and 1.0f. Returning values between 0 and 255 will lower your precision, as a floating point variable can hold much more data than an unsigned character.
Unread 16-12-2008, 17:23
In most cases, the WPI Robotics Library is equivalent between LabVIEW and C++, although the documentation isn't always as good for one or the other. 99% of the time, you should be able to look at the LabVIEW documentation if the C++ documentation isn't clear (and vice versa). Don't get caught up in the name of the document.
I don't believe that is true in this case. I'm pretty sure that DS sends the values to the cRIO as a single byte integer. In this case, they should be equivilent.
If you are trying to directly copy an algorithm from the IFI controller, it may be easier if you use the raw joystick values and the PWM class, but for implementing new things, you'll probably find it easier to work with the floating point values.
Unread 16-12-2008, 22:19
slavik262's Avatar
AKA: Matt Kline
I may be wrong, but in doing basic tests it seemed that the joystick had greater precision than that. What you're saying does make sense though. I'll have to take a deeper look at it.
Unread 17-12-2008, 10:38
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
Originally Posted by slavik262 View Post
I've downloaded that document on two computers and when I open it on both I get "The address is not valid" in the right pane. Is it a problem with the user or the document?
Unread 17-12-2008, 11:39
Is it due to Microsoft's problem with .chm format?
http://forums.usfirst.org/showthread.php?t=10708
Reversing the joystick axis JBotAlan Programming 3 09-02-2005 19:47
Tri-axis Analog Joystick KVermilion Control System 5 19-01-2005 00:24
pwm outputs vs. joystick y-axis stephenthe1 Programming 4 01-12-2004 17:29
Inverting Y axis on joystick FormatteD_C Programming 7 24-02-2004 16:56
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
