Go to Post Well... as ready as we can be 30 days before build season... We definitely do not have a robot yet though... :) - pandamonium [more]
Unread 07-12-2008, 19:39
Billfred's Avatar
Billfred Billfred is offline
Re: Rules: Velcroing Electronics
1618 has used Velcro in copious amounts during my time with them. A tip: standardize which side goes on which part. You don't want to be scrambling to attach a replacement Victor that won't stay put because you mixed your hooks and loops up when you installed it the first time.
Unread 07-12-2008, 20:14
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Today we built up a panel with all the electronics velcroed onto PVC sintra.
I think our final solution will be the cRio velcroed down with an auxilary brace bolted onto the cRio for those high-G turns and stops.
Ed Barker
Unread 08-12-2008, 16:56
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
I have seen a Spike that was attached with Velcro to the inside top of the electronics box come loose in a good impact. Of course, it landed on something bad, resulting in a fair amount of magic smoke and a giant bundle of wires that were melted into one chunk.
Use care if you are going to mount things with Velcro. If bad things can happen if it comes off, you should at least put a wire tie around it before competing.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 09-12-2008, 20:34
Steigerwald's Avatar
Steigerwald Steigerwald is offline
Questionable???
FRC #0115 (MVRT)
Steigerwald is an unknown quantity at this point
Send a message via AIM to Steigerwald
Our team has used a LOT of velcro (too much!) and it seems to work alright for components that are not critical like spikes or sometimes victors. I don't think that velcro on the cRio is a good idea just because of the weight but for the power distribution panel, it should work provided you use the 2" wide stuff and not that small narrow velcro.
MVRT - Monta Vista Robotics Team #115
2009 Robot El Toro 13
2009 Davis Sacramento Regional Finalist
2009 Davis Sacramento Regional Engineering Inspiration Award
2009 Davis Sacramento Regional Best Website Award
2008 Championship Best Website Award
2008 Davis Sacramento Regional Best Website Award
2008 San Jose Best Website Award
2007 Davis Sacramento Regional Best Website Award
2006 San Jose Best Website Award
Unread 17-12-2008, 13:30
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
I don't think we'll ever use Velcro again. In '06 and '07 we used velcro, and replacement was just a hassle sometimes since the velcro backing doesn't always like to separate from the velcro...and as previously suggested alot of times our velcro sides didn't match up.
In 2008, we used #8 and #10 nylon screws. With nylon screws you can drill a hole, hot glue the nut in place on one side, and effectively have the equivalent of a tapped hole. For 2009, we'll probably use rubber-backed washers with steel nuts & bolts for the cRio, and varying sizes of phillips-head nylon bolts for the rest. All will be mounted on honeycomb fiberglass that will have a nice glossy finish put on it in the end.
For the cRIO & PDB, think about the risk vs reward. You'll save a few ounces at the risk of an imperfect <adhesive> connection coming loose. Should the risk come to fruition, the consequence is that you may have to replace a several thousand dollar part that you're supposed to also use in future years' FRC competitions...not just 2009. Is it really worth the risk?
2017 Scoring Model
CAD Library | GitHub
Unread 17-12-2008, 14:28
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Velcro is nice, and fast. But the first, and I mean the VERY first time you have a major failure because the velcro came loose at the worst possible time, you will never use it again.
We use the nylon fasteners. It is a postive connection as opposed to the cross-your fingers with velcro. It's as fast as velcro to install the first time. We also use a product called gatorboard as our electronics board. It's foam sandwiched between two layers of heavy paper. You can poke holes in it with a screwdriver or allen wrench, and it is non-conductive and very very light.
If we didn't get it for free (yes we include it on the materials list), I'd move us to 1/4 cheeseholed lexan because it's non-conductive.
Despite out best efforts during the last invitational match we played in 2007, our chassis was carrying an intermittent 5 volt charge. We never were able to pin down where the leakage was occuring, but since then we'll never use a conductive backplane again.
Unread 17-12-2008, 16:51
rogerlsmith's Avatar
rogerlsmith rogerlsmith is offline
Software Engineer
AKA: Roger Smith
FRC #3357 (COMETS)
rogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to behold
Before using too much Velcro around sensitive electronics, you might want to do some investigations into how much static electricity builds up in it each time you pull the Velcro apart.
Last year we used Velcro to hold our gyro in place and I we always had unpredictable results with that gyro. It may not have been the Velcro, but I became suspicious after a while. I did find some info online that warn people flying model rockets to not Velcro in their altimeters and other instruments.
Roger Smith
Mentor - FRC Team 3357
COMETS - Creating Outstanding Minds, Embracing Technology & Science
Share FIRST videos, photos and experiences at FIRSTObjective.org
Unread 22-01-2009, 21:04
Sleiter Sleiter is offline
FRC #1506
Sleiter is an unknown quantity at this point
I just started using velcro on our electronics this year with the practice robot, i would really like to use it on the competition robot too.
It says in R<59> that we can use "Appropriate Fasteners" but i don't know if that includes velcro or not. If anyone finds out officially, PLEASE POST !!!
Thanks
Unread 23-01-2009, 00:19
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
We're using velcro to hold the CRIO but it is reinforced with several zip ties as well.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Removable Electronics copperhead47 Electrical 28 22-01-2008 02:29
Robot electronics geo Chit-Chat 1 17-02-2007 22:42
Regional-specific rules, etc., and do the referees read the rules? Kit Gerhart Rules/Strategy 53 18-04-2005 08:51
Dilemma - Letter of the rules v. spirit of the rules Natchez General Forum 27 03-04-2003 15:37
Electronics information Neal Probert Electrical 1 11-01-2003 18:56
