Go to Post Being the GDC is not an easy job, anything can happen. Lunacy happened ::rtm:: - Conor Ryan [more]
Unread 17-12-2008, 12:29
programmr's Avatar
programmr programmr is offline
AKA: Face
FRC #0522
programmr is a jewel in the roughprogrammr is a jewel in the roughprogrammr is a jewel in the rough
Send a message via AIM to programmr
Jaguar and Victor Flashing lights?
What does it mean if you have jaguar with a flashing amber light, fan is not moving, and a victor with an amber flashing light, fan moving?
"I would love to change the world but no one will give me the source code"
Unread 17-12-2008, 12:30
Re: Jaguar and Victor Flashing lights?
It means no PWM signal is being sent (or received) from the Digital Sidecar.
This can be because
-- the cRIO is disabled (No comm with the DS, No DS Disable/Enable switch installed, DS Disable switch thrown, broken code trapped by a Watchdog)
-- The code on the cRIO did not open that particular pwm output
-- the PWM cable is not connected properly or is broken
The victor fan was wired to run constantly, without control, directly off the input power while the Jaguar fan is controlled.
Unread 17-12-2008, 12:38
programmr's Avatar
AKA: Face
FRC #0522
ok, well on the ds, it says Battery: No Code, System: Enabled, Mode: teleoperated, Team: 0522, DS Rev: 2008-10-29a... does this mean, theres no program in the cRIO?
Unread 17-12-2008, 12:43
It looks like the code on the cRIO is incorrect.
Did you update the cRIO with the FRC cRIO Imaging Tool?
The latest update file is FRC_2009_v2.zip
Are you running with your own code now?
Are the Jaguar/Victor plugged into PWM 1 & 2 and the Digital Sidecar plugged into the cRIO module in slot 4?
Unread 17-12-2008, 13:00
programmr's Avatar
AKA: Face
FRC #0522
Yes, i updated to FRC 2009 v2. The pwms are in 1 and 2 and the digital sidecar is infact inserted into cRIO module slot 4. Now i configured windriver and read and followed the instructions on page 85-94. How do i know if the program is downloaded in the cRIO? the new way of downloading a program seems to be confusing me greatly? The code ive been trying to download was Simple Robot Template, with no changes to it at all, just whatever is included in Simple Robot Template. No modifications, any suggestions or what should i do or what am i doing wrong?
Unread 17-12-2008, 13:11
Did you try using "Download" under the "FIRST" pulldown on the menu bar,
or are you using "Run"?
Unread 17-12-2008, 13:20
programmr's Avatar
AKA: Face
FRC #0522
ok, yes i did try that, heres how i have it wired: Laptop ethernet to DS ethernet port 2, DS eth port 1 to cRIO eth port 1. Switch on DS is on TELEOP, Competition port switch is :System: Disabled. I click download, the loading bars go across and then it disappears. Am i doing anything wrong? My laptop's IP address is also static at 10.5.22.6 subnetmask 255.0.0.0, default gateway of 10.5.22.4? Am i doing something wrong?
Unread 17-12-2008, 13:28
That all looks good.
Reboot or reset the cRIO to force it to start the new program after a Download.
Run will take effect immediately, but will NOT be there after the cRIO is restarted.
Unread 17-12-2008, 13:45
programmr's Avatar
AKA: Face
FRC #0522
ok, i rebooted it, nothing, so i hit the reset button on the cRIO. But now i cant ping it, or cRIO image it.When i open the crio imaging tool, it shows the crio with the current ip address of 10.5.22.2, but i can't "format" it? I'm really lost here, please assist me as much as you can with this issue. What do i do next?
Unread 17-12-2008, 13:50
programmr's Avatar
AKA: Face
FRC #0522
actually, i got it to reformat... i needed to change the ip on my laptop to 10.0.0.6, please bear with m,e as i try to reupload a program.
Unread 17-12-2008, 13:54
programmr's Avatar
AKA: Face
FRC #0522
now after this is done reformatting, turn off the crio and then turn it on and rthen go to FIRSt and download in windriver?
Unread 17-12-2008, 14:00
Make sure the reformat works and the jaguar/victors work before you try downloading again.
Also your laptop IP should now be 10.5.22.6
Unread 17-12-2008, 14:06
programmr's Avatar
AKA: Face
FRC #0522
ok well, the jaguars and the victors are still flashing amber. however on the DS it says battery:00.00V... but now on the NI9742 module, the leds are now flashing left to right and right to left, which it didnt do before. However the jaguars and the victors are still flashing amber? Thank you for helping me through this long process. What should i do now?
Unread 17-12-2008, 14:16
The flashing lights indicate that you are in autonomous mode in one of the default codes (I can't remember which).
The 00.00V indicates that you are missing a Jumper on the battery select jumper on the analog breakout in slot 1.
Unread 17-12-2008, 14:19
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Mark, We have not received our station yet, but hope to this week.
I am trying to stay on top of all the documentation and updates so that we are ready, once it arrives, to perform the OTB testing followed by updating everything, in order, to the correct versions. The only piece of this I don't seem to have is the cRio update "FRC_2009_v2.zip". Where can I find this? Is it on the DVD's that come with the kit, or elsewhere?
Jaguar Failure Jon236 FRC Control System 21 23-12-2008 18:30
pic: Jaguar next to Victor ajlapp Extra Discussion 26 10-08-2008 17:56
Lights on Spikes and Vics merybar Electrical 4 25-01-2008 21:18
Victor Lights robobrain0101 Technical Discussion 9 13-02-2007 15:18
Flashing Red Robot Feedback Lights zarf Programming 2 12-02-2005 16:01
