Go to Post Point is, there is no definite answer. This is FIRST, Whatever works well with your team is the best. - NelsonMichael [more]
Unread 23-06-2002, 23:56
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Additional Hardware -- Switches
Posted by Jay Lundy at 1/31/2001 7:18 PM EST
Student on team #254, The Cheesy Poofs, from Bellarmine College Preparatory.
Hey,
We're planning on using a switch to control a function on the robot but we dont want to use a rocker switch. Instead we want a switch that stays in position after it is pressed. What kinds of additional switches can we use?
#0047 (ChiefDelphi)
any
Posted by Joe Ross at 1/31/2001 7:37 PM EST
Engineer on team #330, Beach Bot, from Hope Chapel Academy and NASA/JPL , J&F Machine, and Raytheon.
In Reply to: Additional Hardware -- Switches
Posted by Jay Lundy on 1/31/2001 7:18 PM EST:
You can use any switches on the Operator Interface. See team update 3.
Head down to radio shack (or Fry's since you are in California) and go to town :-)
#0047 (ChiefDelphi)
Re: Additional Hardware -- Switches
Posted by Matt Leese at 1/31/2001 8:02 PM EST
Other on team #73, Tigerbolt, from Edison Technical HS and Alstom & Rochester Institute of Technology.
You can use any switch that you like, as long as it's not lighted. They can get expensive however.....
Matt
#0047 (ChiefDelphi)
Posted by Josh Vetter at 2/1/2001 9:49 AM EST
Student on team #548, Robostangs, from Northville High School and BOSCH.
A toggle switch would stay in place after you switch it. You could also use the rocker switch, and program it so that when you press it one way, it remains like that until you push it the other way.
Josh
: Hey,
: We're planning on using a switch to control a function on the robot but we dont want to use a rocker switch. Instead we want a switch that stays in position after it is pressed. What kinds of additional switches can we use?
[IMG] code is Off
additional hardware + tools archiver 2000 4 24-06-2002 00:20
Additional hardware list archiver 2000 5 23-06-2002 22:54
Additional Hardware list confusion archiver 2001 4 23-06-2002 22:29
gear thickness zarb Technical Discussion 10 26-01-2002 22:07
Are additional pulleys "cable fasteners"? kmcclary Off-Season Events 6 26-10-2001 01:56
