Go to Post rebound rumble didn't really have a lot of rebounding or surprise earthquakes. - Rynocorn [more]
Unread 17-12-2008, 13:42
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
HELP reimaging
We are at the point where we are re-imaging and after we release the "Select" button, the screen quickly flashes "Do NOT SHUT OFF Process Takes Several Minutes" then the screen goes back to Team:00000, etc.
I will also add that I had some students who wanted to work on the system installed the Wireless connection already. I'm not sure if this is why it is not working, but they went ahead to a step prior to us re-imaging.
Please Help! Thanks
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 17-12-2008, 13:56
Re: HELP reimaging
The wireless work done out-of-step won't affect this.
Usually, this happens when the file is named incorrectly on the memory stick, or the memory stick itself isn't compatible or has something else unique about it or in files on it that mess things up.
Try a different memory stick.
To be sure the file is named correctly put two files on it:
-- dsud_pkg.bin
-- dsud_pkg (in case the PC has file extensions hidden)
Unread 17-12-2008, 14:33
RMS11's Avatar
Safety!!!!
AKA: Rick
Team Role: Driver
Re: HELP reimaging
Thanks, we will try this out. Would naming the file in caps have ant effect?
Unread 17-12-2008, 15:01
Re: HELP reimaging
It should accept an upper case name too.
Unread 17-12-2008, 21:21
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
Re: HELP reimaging
Make sure the flash stick doesn't have any auto-start programs on it. I borrowed an empty stick when I did it because mine is really a formatted 8 GB hard-drive with anti-virus and other programs running on it.
You can check that the file is a *.bin file by going to <View><Details> before plugging into the DS.
Team MARS = 1.523 AU from the SUN!
Jim E.
Grab Frame - Help Help Help... nmihailidis Programming 2 04-03-2007 14:44
section 'InterruptVectorLow' type is non-overlay (was: HELP HELP HELP!!!!!) naor52 Programming 14 24-02-2007 01:19
Help: How do we get a teacher to help? (was: Help) ChaosAlchimey General Forum 13 21-01-2007 11:57
