Go to Post I'll try to sum up the icon and compile thing quickly so as not to interrupt the design of SkyNet. - Greg McKaskle [more]
Unread 17-12-2008, 18:59
mole mole is offline
AKA: Anmol Dhar
FRC #0772 (SabreBytes)
mole is an unknown quantity at this point
FRC CompactRIO firmware upgrade help
I've been trying to update the firmware on the compactRIO processor for quite some time now using the guides provided my FIRST and NI and by reading posts here on chiefdelphi but i cant seem to get it working.
I hooked up the laptop to port 1 on the CompactRIO using the orange crossover cable provided in the early kit of parts. After I switched the IP address to 10.0.0.6 and the subnet mask to 255.0.0.0 i started the CompactRIO Imaging Tool. As soon as it starts it says files cant be found such as : NiRioSrv.dll and so on and so forth. Then after ignoring them all the imaging tool pops up and it says searching. No matter what i do it doesnt work!! please help
Thanks,
Team 772
Unread 17-12-2008, 19:03
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Re: FRC CompactRIO firmware upgrade help
I am not sure what exactly is wrong with the Imaging system from your description, but you will get more help faster if you post on FIRST forums instead. FIRST developers are monitoring those forums more closely!
-Borna Emami
Team 0x27
Unread 17-12-2008, 19:34
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Thanks,
Team 772
Did you install the DVDs that came in the early control system kit?
If not, install this and it should solve your problem.
If you did, then did you have LabVIEW 8.6 installed before you installed the DVD? If that is the case, you need to run the NI-RIO 3.0.1 installer so that it will install NI-RIO support for LabVIEW 8.5.1
Cheers!
-Joe
Unread 04-01-2009, 14:07
Tim Skloss's Avatar
Tim Skloss Tim Skloss is offline
Dr. Skloss
FRC #0930
Team Role: Parent
Tim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the rough
We have the same problem on one laptop, but not another. The working one is running Windows 98 and the one with the problem is Vista.
Complete uninstallation and reinstallation of the 2 early release disks and Update2 still doesn't fix the problem.
What could be causing this missing file??? Anyone figured this out?
FIRST Mentor and Team Leader
C.O.R.E 2062 a NASA, GE Volunteers and Rockwell Automation FRC Team
Unread 05-01-2009, 14:45
AKA: Brad
#0190 ( Gompei and the Herd)
Thanks,
Team 772
Did you do the full FRC install or are you running from a version of LabVIEW that you downloaded or got from somewhere else? I'm not sure, but it sounds like the NiRioSrv.dll is from some uninstalled part of the LabVIEW runtime system.
Brad Miller
Robotics Resource Center
Unread 05-01-2009, 15:36
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
I updated our cRIO yesterday with a Windows Vista laptop so I don't think it is an OS problem.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 07-01-2009, 21:28
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
We are suffering the same problem. Running with administrative privileges does nothing.
A2D Solving the Imaginary Error Function...
Unread 09-01-2009, 20:35
AKA: Brennan Ashton
FRC #2605 (A2D_16)
It turned out that the issues was that I had the Labview NXT plugin installed, soon as I uninstalled it, I was able to install the NI-RIO stuff that was linked earlier.
Unread 17-01-2009, 18:46
Tim Skloss's Avatar
Dr. Skloss
FRC #0930
Team Role: Parent
Hot dog! That was it! Great catch and I am sooooo happy now that I can work on LabView!
Thanks a million for posting the solution. Let me know if you are going to be at the Minnesota or Wisconsin regionals, I owe you a lunch.
Buying new RC - CompactRIO Daiane General Forum 7 22-09-2008 16:03
C or LabVIEW: CompactRIO markulrich Programming 38 02-05-2008 11:21
CompactRIO - new Control System by NI ND4SPD Programming 1 17-04-2008 21:46
Firmware 14 bear24rw Programming 2 03-02-2007 10:53
Help Upgrade CD Steve W General Forum 60 07-04-2005 22:44
