Go to Post Be civil in all things and you will get far. - Wetzel [more]
Unread 18-12-2008, 12:03
sparrowkc sparrowkc is offline
AKA: Mark
FRC #1986 (Team Titanium)
sparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to behold
Re: Default code doesn't seem to match documentation
http://usfirst.org/community/frc/content.aspx?id=10934
Have you done all the software updates on this page? The NI update changes the default template, and updates the image used by the crio imaging tool. You need to reformat the crio before the updated default code will work on it.
Code for sensor still doesn't work Ianuser Programming 3 14-02-2007 10:17
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
even simple autonomous code doesn't work?? colman77 Programming 4 17-02-2006 23:58
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
