Go to Post I am alive today because I can't hold onto things. - Al Skierkiewicz [more]
Unread 18-12-2008, 13:05
grambo's Avatar
grambo grambo is offline
AKA: Jonathan
FRC #0238 (Cruisin' Crusaders)
grambo is an unknown quantity at this point
torque spec?
Anyone have a torque spec for the large terminals on the new power distribution board? I snapped off about half of our negative terminal when we assembled our kit a couple weeks ago... It's been hanging on by a thread (maybe two) so far on our old robot. Definitely a mistake I'd rather not repeat once we get the kit of parts.
Unread 18-12-2008, 13:13
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: torque spec?
I could just be uneducated here, but I don't think teams who received their controls early will be getting a second set in the KOP.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 18-12-2008, 13:16
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: torque spec?
Nope, you are correct.
Unread 18-12-2008, 13:30
Re: torque spec?
Wow. Whoever managed that just earned themself a nickname or two. Around the office we use the last name of a particular individual as a unit of torque. A "half-_____" is equal to the amount of torque necessary to irreversibly bind a bolt. A "full-____" is equal to the amount of torque necessary to destroy a bolt.
I am reasonably certain that you will not be able to return this PD, your best bet is to buy a new one from AndyMark.biz
The spec I have is "Torque 0.6N per Pin" (25 pins). Since I'd expect torque to be in Newton meters, I will check with the manufacturer for the actual spec.
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: torque spec?
YIKES!!!
Did you use a 1/4-20 nut or an M6 nut? Make sure that you're using an M6 nut. You've obviously got the positive terminal connected fine, though. Is it possible that you've got an M6 on the positive and a 1/4-20 on the negative?
http://www.we-online.com/website/fra...rDOCID=1010821
The PD uses the Wurth 7461098 shank for connections (see above for datasheet in "power elements"). Unfortunately, the above link doesn't include such specs but I'm guessing that someone knows how much torque is required to snap an M6 bolt of ? metal. I guess that it's possible that your shank was somehow defective in its metallurgy or machining.
At work, we call this much torque a "Hillis" or a "mega Hurley" (also 1 microHillis = 1 Hurley) in honor of a few of our staff. You might want to try using a shorter wrench next time (or maybe finger-tight in your case)
Oh snap...
Russ
Unread 18-12-2008, 13:31
cdennisxlx2's Avatar
cdennisxlx2 cdennisxlx2 is offline
Team San Diego Web Liaison
AKA: Cameron Dennis
FRC #1266 (The Devil Duckies)
cdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to behold
Re: torque spec?
AndyB is correct, you wont get a second one in your KOP [until 2010, lol]. The good thing is you can buy a new one Here
Hope that helps, good luck this season
Team San Diego Robotics Web Liaison
Webmaster and Technical Advisor for the San Diego Regional Planning Committee.
Official Score Keeper for the San Diego Regional
www.sandiegoregional.com
www.frc1266.com
Unread 18-12-2008, 13:40
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Re: torque spec?
Just to add to the discussion:
Judging from you photo, the bolts look like they are brass, which would have a much lower yield strength than steel. Contact the manufacturer, as you may be able to replace the broken terminal bolt/nut. However, I am only guessing, since I haven't seen or handled the component as yet.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 18-12-2008, 13:56
Re: torque spec?
Unfortunately, the bolt is press-fit (one chance only) into the PD's PCB using, to my understanding, a massive press at Diversified Systems. In other words, it cannot be replaced since, even if you could push it back out of the PCB, it would probably never re-engage properly (too much damage to the PCB's through-holes).
Russ
Unread 18-12-2008, 14:06
Re: torque spec?
Russ
The connector is rated for 250A continuous. To get that sort of ampacity, they literally shove square pegs into round holes - solder just wouldn't do it.
Very good for reducing the total resistance drop through the PD, not very good for fixing broken shanks.
Unread 18-12-2008, 14:09
Engineer's Avatar
Engineer Engineer is offline
KØBR
AKA: Rick - KØBR
FRC #3007 (RoboTitans)
Engineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of light
Re: torque spec?
I have not seen the part either but here is a "handyman/shadetree/garage mechanic" fix for broken studs like this. Use a long nut to hold both pieces together. Drill down the center with an #30 or #29 drill in a drill press. It is important to go straight down. Drill through both pieces. You can remove the nut after you've drilled the hole. Now get a 1/8" brass rod and cut it the length of both pieces. File a flat on one side of the brass rod the entire length. File or cut a slot at one end about .030" wide and .0625" deep. Use a good flux and cover the surface of the brass rod and the hole you just drilled in both pieces. A Q-tip works well for getting the flux in the hole. Now you are going to solder the brass rod in the hole to join both pieces. The flat you filed in the rod will give the solder a path to flow down and the slot will allow you to use a small screwdriver to turn the brass rod to help all surfaces get covered with solder for good joint while it's hot and the solder is molten. Use a high wattage solder iron/gun or a torch works well also to produce enough heat over the large area.
Watch the heat carefully so you don't melt something you down want to melt.
Be very careful tightening the nut as it will only handle less than half the torque it did before you broke it. Good luck.
2008 GM Industrial Design Award (2232)
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- WOW -- What A Ride!" Anonymous
Hello, from KØBR.
Unread 18-12-2008, 14:18
billbo911's Avatar
Re: torque spec?
This is just a thought, and not a verified solution.
By the looks of this from the picture, there might still be about three threads left on the stud.
If you can find (or make) a M6 standoff with a male shaft on one end and a female on the other, you might just be able to "patch" this PD.
Make certain the female end engages the remaining stud by three threads, tighten it to spec. Then you should be able to connect the negative wire to the stud on the standoff.
Again, I would not use this repair on a competition robot, but it should be good enough to salvage this one for learning and practice robots.
Man, that was a $189.00 booboo.
Unread 18-12-2008, 14:58
Re: torque spec?
Erik and Russ,
We also have a whole specification of measurements based on the OR (for Ed Or****) Since Ed was a rather large guy and was fond of using tools in much different configurations than their intended design, this table was developed.
1 OR=720 ft. lbs based on Ed's estimated weight and his penchant for using a 2' pipe to get better performance from his wrench.
Screwdrivers had to be able to survive as cold chisels and cresent wrenches needed to double duty as hammers. To give you and idea of his power, a co-worker once glued his toolbox in place on a formica covered bench using RTV. (It was a joke, you had to be there) When he attempted to remove it, he lifted a rather large oval shaped piece of the formica covering from the bench top. The formica and tool box lived as a single unit for many years. Ed is now retired and so is the toolbox. On occassion he was known to measure distance in femto parsecs.
Unread 18-12-2008, 15:15
Re: torque spec?
I just finished conversing with our Wurth rep. He send me a small ppt with the appropriate specs. I can email it to you if you'd like. Unfortunately, it is pictures of text with bad compression...
Summary:
Max Torque 3.9 Nm -
Break torque 10 Nm - Destruction of threaded shank
Break Torque 25 Nm - Destruction of the press-fit pins
Upon seeing the photos, his immediate response was that you probably used a 1/4-20 nut instead of an M6 and then cranked it. I'm not sure what the root cause is, but we can swing this as a reminder to all teams:
Only use M6 nuts on the PD Shanks.
Don't force any connectors.
More Info just received (in new legible text format!!):
Mechanical properties (reference values):
Material: CuZn39Pb3
Shear-off force: 350 N/mm²
Tensile force: 480 N/mm²
Tensile yield strength : 340 N/mm²
Elongation: 20%
E-Module: 96 kN/mm²
Torsion-Module: 32 kN/mm² (shear modulus)
Unread 18-12-2008, 15:59
Re: torque spec?
When they heard about your plight a friend of mine suggested a very temporary workaround would be to employ one or more of the unused 40A return lines to replace your "-" terminal.
That'd only work if you could insure that your load didn't get too high. That Wago is only rated for 76A continuous, but it will be much better than using a unknown fix for the shank.
Best to just buy a new one...
Unread 18-12-2008, 19:15
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: torque spec?
I noticed a new robot student tightening the nut on one of the terminals with a ratchet, and said "that's tight enough!" just in time
This was after another mentor had to go to his truck to find a 10mm socket.
Thanks for posting this warning, this is good info on this thread
Error in dashboard spec Don Reid Programming 6 09-02-2006 12:39
Fisher Price Spec? Raul Motors 10 27-01-2004 13:24
Chiaphua Spec Sheet Joe Johnson Motors 12 09-01-2003 16:01
How fast could a torque motor turn if a torque motor could.. archiver 2001 0 23-06-2002 22:54
