Go to Post "The devil" isn't in the details... The devil is having a loud house party with lots of other devils and demons in the details. And laughing, and laughing... - pfreivald [more]
Unread 18-12-2008, 13:27
Re: Default code doesn't seem to match documentation
For Basic Framework - in the Block Diagram for "Basic Robot Main.vi" on the top left you'll see them. (I'd recommend not using the Basic template for now- it has a bug that I'm sure a later patch will fix.)
For Advanced Framework - in the Block Diagram for Begin.vi towards the bottom in the center "column" you'll see them.
Documentation always lags production sw...
When you created your project did you see the choice for Basic vs Advanced framework shown the the right photo below?
If not then you haven't installed the LabVIEW FRC update.
ID:	7039  Click image for larger version
Code for sensor still doesn't work Ianuser Programming 3 14-02-2007 10:17
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
even simple autonomous code doesn't work?? colman77 Programming 4 17-02-2006 23:58
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
