Go to Post We are just helping to keep Home Depot from going Bankrupt :D . - E. Wood [more]
Unread 19-12-2008, 00:47
EricVicenti EricVicenti is offline
FRC #0008 (Paly Robotics)
EricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura about
Advantages of the Jaguars?
While it is clear the Jaguars have a lot of new features, it seems we won't be allowed to take advantage of them in the 2009 season. They have a few wire clips and a nice cover for the fan. Other than that, they are slightly heavier, considerably larger, and in much shorter supply than the victors. What advantages do they have over good ol' victors, aside from being shiny and new?
Unread 19-12-2008, 01:30
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Re: Advantages of the Jaguars?
Disclaimer: I am a mentor for Team 2468 by night, but a systems engineer at Luminary Micro by day. So, I am biased.
Pros:
- Jaguar costs less than a Victor 884, more than $40 less ($73.33 vs $114.99).
- Better output linearity (see http://www.chiefdelphi.com/forums/sh...6&postcount=86). If you want to see a demonstration of this, see http://www.youtube.com/watch?v=_X0_aFMpm9I.
- Integrated limit switch inputs (one forward, one reverse)[*].
- Controlled fan turns on only when H-bridge is generating a non-zero output voltage (8 fans amount to 0.5 A).
Cons:
- Bigger than the Victor 884.
- New kid on the block; teams have less experience with Jaguar compared to the Victor 884.
I am not sure how you determined the availability of one controller compared to the other. You can check the inventory at Digi-Key, but this doesn't indicate how many are in the pipeline (only how many are currently in Digi-Key's warehouse).
[*] The status of the limit switch can be made available to the cRIO with a small circuit that I will publish as a Jaguar application note after the holidays. This circuit is necessary in order to assure that additional ground paths are not created from the motor controller through the DSC.
Unread 19-12-2008, 03:10
As far as availability, I was referring to the fact that most teams probably have a few victors lying around, and many veteran teams definitely have a lot of victors lying around. I wasn't aware of the lower price, however. Also, the output linearity tests you linked to were very definitive. I had no idea the victors were so poor .
At this point, I am much more impressed with the Jaguars than I was initially. Now we just need to find an efficient way to organize these.
Unread 19-12-2008, 07:56
Gdeaver Gdeaver is offline
FRC #1640
The new Jags are also thermally and current limited. With the Victors we have been running open loop and things just kept going until something fried or a breaker tripped. In the real world companies that design motor controllers and use variable speed motor have to contend with something called a warranty. Protections are essential if a company doen't want to go bankrupt from warranty claims.
Unread 19-12-2008, 10:05
AKA: Scott McMahon
Yep.. and teams are free to choose what they want to use.
This constantly disturbs me. Luminary Micro is providing a price brealk for FRC teams, but you have to go to a specific Digi-Key web page. Otherwise, the cost to NON-FRC teams is $109, which is only a 6 advantage. Please use http://sales.digikey.com/dkes/FirstR...ompetition.asp if you decide to order more Jaguars beyond those provided in the KoP. This link is also available at the bottom of the Jaguar web site at Luminary Micro (http://www.luminarymicro.com/jaguar).
One of our students came to the simple observation that if you stand on on its end (with the cable retention clips pointing up to the sky) you can put two of them back to back (fans facing in opposite directions) and take only a little more space than laying flat on a table. Our team will probably experiment with this orientation if space becomes tight.
Unread 20-12-2008, 10:37
DonRotolo's Avatar
Back to humble
FRC #0832
Add to the list of Pros "the cool name"
In the future (2010 or beyond) the ability to run these on a CAN Bus will prove to be valuable to some teams.
The Jaguars have all of the features of the Victors - and much more, along with better linearity and range, plus they are less expensive to teams. A win-win-win all around.
One thing I'm worried about is the ability to clean them. With the victors, if we suspected a bit of wire or metal shaving accidentally got in there, we could clean it with compressed air easily. Does anyone know how the cover comes off a Jaguar for cleaning?
Don
Unread 20-12-2008, 10:52
Billfred's Avatar
Billfred Billfred is offline
One of the college students on 2815 was able to open one up and re-close it without incident. (Have to show the kids all the juicy innards, yes?)
Unread 20-12-2008, 11:20
Boydean's Avatar
Boydean Boydean is offline
The Blue Alliance
Boydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant future
Send a message via AIM to Boydean
I just hope their more robust then the victors. I don't know how many wasted hours(in about 5-10min blocks) we spent trying to get the things to get a single. It would get it once, then the robot terns off and back on then all the sudden it doesn't have a single...those little flashing red LEDs would give our team a collective a "sigh".
But hey they were free, and they ran our robot straight through championships.
Unread 20-12-2008, 14:13
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I don't mean to pick on you, but I've seen a lot of posts like this.
The only failures we have EVER experienced with the IFI system and any of it's components have been our own fault.
We have had only a couple incidents I can recall. One fried an entire RC, a couple other times we had connectors shear off of it because of our own stupidity.
My point is that if you experienced systematic problems with the IFI control system, it was probably something you were doing incorrectly, because when used properly all of IFI's stuff just plain works. Do their products have things that could be better? Sure, everything does, but what they have is pretty darn good.
It's also not fair to IFI, who has been a fantastic supporter of FIRST, to insinuate that their products are anything less than quality, which is clearly not the case.
2001-2004: Team 100
2006-Present: Team 254
Unread 20-12-2008, 14:19
First of all, yea i have to agree with this. Any team that has ever asked us for help with any of the IFI system components has explained their problem and then we found out that it was their own fault that made them have a system failure or a fried part.
Secondly, I know my POV on this subject, but do you guys think that the benefits outweigh the drawbacks? ie: weight (nto so much) but size?
Unread 20-12-2008, 14:28
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
The footprint is larger, yes, but it's not bad at all. The future ability of using CAN far outweighs the size issue. I can't wait to get rid of these PWM cables.
Unread 20-12-2008, 14:29
NickE's Avatar
NickE NickE is offline
_
For 2009, I still see the victors as the clear choice due to their size. The jaguars really don't have any features (legal for use in 2009) that outweigh their massive size.
Unread 20-12-2008, 14:44
Pros:
How do we turn off this feature to run the fans constantly? Once hot, a FET wants to be cooled down even if it is not passing current. And I hope this doesn't mean the fans are connected to the output of the H bridge.
Unread 20-12-2008, 14:52
Billfred's Avatar
Al,
This post seems to indicate that the conditions for the fans shutting off are that the motor is off, and 10 seconds have passed, and the temperature is below 38°C (roughly 100°F). I'd assume that's a safe temperature for the Jaguars, since they set the number.
Unread 20-12-2008, 14:53
wilsonmw04's Avatar
Coach
Bill beat me to it.
Al, They don't turn off as soon as current is removed. In my experience, as soon as you ask the Jag to do something that fans turn on. Once you stop working the Jags, the fans stay on for a certain period of time (~ 1 minute). I'm not sure if it is time or temp dependent.
Diffrent Transmission Advantages lenny8 Motors 31 27-12-2008 11:50
Advantages of ADD in a High-Tech Career Conor Ryan Career 35 16-04-2006 13:10
From the Ice Age to Robot City. The Few, The Proud, The Machines (new movie) Elgin Clock Televised Robotics 21 14-03-2005 15:14
Survey of the 2004 NJ Regional- The good, the Bad and the So-So Rich Wong Regional Competitions 23 10-03-2004 06:23
pic: The Man, The Myth, The Legend, The Symbol CD47-Bot Extra Discussion 6 09-04-2003 02:48
