Go to Post I walked out to the area where the robot was getting ready to move, and there's no room near the robot. I look again, and realize it's all students. - rachakate [more]
Unread 19-12-2008, 13:09
Team 1708 Dave's Avatar
Team 1708 Dave Team 1708 Dave is offline
Lead Robot Inspector
Team 1708 Dave is on a distinguished road
Driver Station Setup??
We were tring to setup the Driver Station today using the instructions provided by FIRST. We held the (down arrow) button down for way over the suggested 5 sec. We could not get to the screen to change the team number screen. The directions seem straight forward. We also tried various sequences ei.. holding it down before the software loaded and during power up. But this was done only after the prescribed method didn't work. Anyone out there have a sim exp.??
Unread 19-12-2008, 13:28
Re: Driver Station Setup??
This is a stupid question, but it has to be asked: Did you update the Driver Station firmware first?
A followup question: What does the display say after the Battery: label?
Unread 19-12-2008, 13:42
psyco_klown's Avatar
psyco_klown psyco_klown is offline
aka Shawn Burgen
FRC #0839 (Rosie Robotics)
psyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to behold
I had the same problem till i pressed harder on the button. They do move quite easy but doesnt mean you have pressed it. It still works after you update the firmware. We updated before the bench test and it works just fine.
Shawn Burgen-FRC Team 839 Mentor
Team 839 FTC Mentor
Unread 19-12-2008, 15:11
You know... How many times did I read "Update the firmware" on this site. And what's the 1 thing we didn't do. As far as the reply about the battery: Battery: N/A Also there is a ** OTB ** on the bottom of the screen.
Unread 19-12-2008, 15:20
aka Shawn Burgen
Beware if you update the ds you have to update the cRIO too to able to talk each other.
Team 839 FTC Mentor
Unread 19-12-2008, 15:22
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
As everyone else has said, update it. We were having that problem, gave up, then updated it. After updating, we were able to hold the button down to work.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 19-12-2008, 15:34
Yes!! That will be our plan of attack Monday. Update the firmware. Any other tips anyone would like to share on this topic?? How about that "OTB" ??
Unread 19-12-2008, 17:42
darkember darkember is offline
AKA: Billy
FRC #0375 (Robotic Plague)
darkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of light
When you load the firmware make sure to change the file name to the one specified on first website. It took us some time to figure out why the firmware didn't load because of that mistake.
Unread 19-12-2008, 17:50
BrianT103's Avatar
BrianT103 BrianT103 is offline
AKA: Brian Taylor a.ka. BT
FRC #0103 (Cybersonics)
BrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud of
Send a message via AIM to BrianT103
OTB = "Out of The Box", this text will disappear as soon as you upgrade the firmware.
Unread 19-12-2008, 23:09
The "N/A" and "OTB" both confirm that you indeed didn't do the firmware update. Oops.
Securing the Driver Station? Madison FRC Control System 16 16-12-2008 03:05
Mounting the Driver Station...? 1708xMr.Roboto FRC Control System 1 15-12-2008 12:34
driver station doesn't see robot nickmagus Programming 4 29-11-2008 23:58
2009 Driver Station Dimensions noxryan FRC Control System 5 27-11-2008 21:02
size of driver playing station 663.keith Technical Discussion 1 11-01-2005 13:23
