Go to Post Actually, I think the standard Klingon warning label ought to be sufficient: 'yIQIpQo' (don't be stupid) - Alan Anderson [more]
Unread 19-12-2008, 17:52
team2845 team2845 is offline
clwillingham
FTC #2845 (Team Duct Tape)
team2845 is an unknown quantity at this point
[FTC]: Field Timer (similer but not the FMS)
Hello. i just wanted to post a program we wrote in LabView using the sourceCode of the FTC Controller station. it is still the controller station but it is set up to activate and deactivate the robot at the correct times. basically you push start and the robot will start on whatever setting you want, it will then start the timer and the robot at the same time, then after either 2 minutes or 30 seconds depending on what you set it to, it will stop the robot. it is the closest i have gotten to making somehting like the FMS and it works well. if you want to try it out please go to
https://sourceforge.net/projects/fieldtimer/
please tell me how you like it. i am having a little trouble getting any feedback on what could be different or if there are any bugs i have not found.
Team2845
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
pic: Not the end of the Rainbow, but .... skimoose Extra Discussion 15 02-08-2006 23:46
Camera did not work for well at the regionals, but worked great at home. Alan Ing Programming 12 17-04-2006 17:43
She'll cheer for the Nimrods, but not for FIRST? Nick Seidl Chit-Chat 3 26-03-2004 15:03
the 50 point not touching the field rule slavik Rules/Strategy 15 11-01-2004 22:00
