Go to Post The only constant in FRC is change. Learning to adapt to change in competition is the best way to prepare for change in real life. - Jessica Boucher [more]
Unread 19-12-2008, 17:48
darkember darkember is offline
AKA: Billy
FRC #0375 (Robotic Plague)
darkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of light
How many teams had router problems?
We were just wondering how many teams had problems with communications do to the routers. We bricked both of our routers before and were wondering why that happened. Fortunatly we were able to unbrick the routers.
Unread 19-12-2008, 18:15
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
Re: How many teams had router problems?
Please detail the symptoms. What do you mean "Bricked" your router?
I am guessing that you mean that your router was inoperable to the point where you had to reset it to factory configuration?
We've had problems with the router, but mostly attributable to operator error, and never to the point where the router was "Bricked".
Unread 19-12-2008, 18:50
AKA: Billy
The router wont comunicate with the other router. At first the router works ( we were programming at the time), then it doesnt. We tried resetting, turning off and on, and even connecting directly to a computer to anaylize the problem. The router normally has a light that shows that it is transmitting wirelessly. That light was off. The only thing that did work was getting it back to factory setting.
Unread 19-12-2008, 19:47
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Something you need to clarify is which device is malfunctioning. The device on the robot is the game adapter, and the drivers station device is the router/access point.
Which device(s) did you reset?
Eric Haskins KC9JVH
Unread 19-12-2008, 20:00
AKA: Billy
well the first time was the driver station router(which we fixed). Today our game adapter stopped working. We still haven't done a factory reset on the gaming adapter but that is what we are planning to do.
Unread 19-12-2008, 21:38
AKA: Eric Haskins
I found reports that this router has issues when running in dual-band N mode. Make sure you've disabled N on the 2.4ghz band.
Its also possible you're getting interference from other nearby networks. You should identify any other networks, and make sure you're running on another channel.
If you still have issues you may want to contact FIRST about getting a replacement.
Eric Haskins KC9JVH
Unread 19-12-2008, 21:41
AKA: Billy
Thanks, that might help us save some time in trying to get it back to work.
Unread 31-01-2009, 14:17
star_lancer's Avatar
star_lancer star_lancer is offline
Programming Addict
AKA: Mike Berney
FRC #2346 (CRASH)
star_lancer is a jewel in the roughstar_lancer is a jewel in the roughstar_lancer is a jewel in the rough
Send a message via AIM to star_lancer Send a message via Yahoo to star_lancer
Exclamation Re: How many teams had router problems?
We're having problems with our router too. We can't access it through the initial IP address, could someone help us?
If you found anything I said helpful, please click the scales next to my post. I really appreciate those reputation points.
Team 2346 - Build, test, panic, repeat.
Unread 31-01-2009, 21:22
You can use the reset button on the back in case the router IP has been set incorrectly.
While the router is on use a paperclip to press and hold the reset on the back of the unit. When the router power button begins to flash you can release the reset.
Then set your PC to use DHCP, and try browsing to 192.168.1.1 again.
How many SD teams in 05? JP_1163 FIRST-related Organizations 0 01-10-2004 11:50
how many of u actually used the stacker if u had one? HolyMasamune General Forum 21 14-04-2003 13:12
How many teams.... archiver 2001 0 24-06-2002 04:03
How many teams? archiver 2000 9 24-06-2002 00:37
How many teams.. archiver 1999 8 23-06-2002 22:53
