Go to Post The programmers tend to get less credit than they deserve, but the robot wouldn't run if we weren't there. :) - IMDWalrus [more]
Unread 19-12-2008, 23:29
run the trap!!!
Team Role: Human Player
Re: Help!!..wheels?
We press-fit the colsons on the AM hubs and put three 10-32's through the hub plate to secure them.
Works great and takes like only a couple minutes to assemble.
-Philip J. Fry
Unread 19-12-2008, 23:56
CraigHickman
Posts: n/a
Re: Help!!..wheels?
Originally Posted by Hachiban VIII View Post
... but it doesn't stay new for long
I agree with you here, for wedgetop. Blue Nitrile Roughtop is among the most durable tread materials I've used. Over the 2007 and 2008 season, using the robot for both competition and demos, we NEVER changed our tread on each bot. Never had a problem with roughtop wearing. Wedgetop, on the other hand....
Nitrile roughtop wears extremely well, and is a good compromise for this situation. I still prefer natural rubber or SBR tread, and just changing wheels often. It seems to be worth the traction advantage.
Nitrile rocks. Never had a bad experience with it. Just lay it against an AM wheel that's been stripped of the polyurethane, drill some holes and slap a few pop rivets in. It's janky, but it WORKS.
Originally Posted by gorrilla View Post
also the weight distribution over the wheels, could be a factor on the quickness of wear,
last years robot was two wheel drive with almost all the weight on the front two, we had great traction, but we couldent turn well, and the tread wore down to nothing after the FL. Regional!
Yeah, weight distribution is key. I've mostly used roughtop on our 6 wheels, and had no problems there. The closest we got to wearing tread out was on our 2005 Crab Drive, for Triple Play, and that wasn't bad enough for the bot to be at a disadvantage.
Seriously, if you do your attaching right, you can't go wrong with Blue Nitrile (assuming FIRST keeps the carpet....).
Unread 20-12-2008, 00:54
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Help!!..wheels?
If FIRST doesn't stay with it, go with red linatax.
R.C.
MadTown Robotics Team 1323
Unread 20-12-2008, 01:05
CraigHickman
Posts: n/a
Re: Help!!..wheels?
Red Linatex technically has a higher coefficient of friction than Blue Nitrile Rughtop, on FRC carpet. So if a team has the money, go for Linatex every year. It wears insanely well, and is grippy like no other. Only problem is the cost... It's MUCH cheaper to go with Blue Nitrile, at least from the suppliers I've found...
Unread 20-12-2008, 01:10
R.C.'s Avatar
Re: Help!!..wheels?
Craig, I was going for the icy floor! Lol.
R.C.
Unread 20-12-2008, 01:13
CraigHickman
Posts: n/a
Re: Help!!..wheels?
That would be fun.... Though I'd be a fan of carpet with either a fence or a BIG ramp in the middle... Stack attack style, y'know?
On the topic of wheels, keeping cost under consideration from the beginning is key. If you don't design for your end requirements, not too much point in what you're doing. Billfred brought up some GREAT suggestions. He's cool, so his posts deserve reading extra carefully.
Unread 20-12-2008, 01:18
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Re: Help!!..wheels?
We've used IFI wheels in the past with decent results but the tread is a pain to replace. This year we are looking at the AndyMark Plaction wheels, basically kit wheels with a system for easily using conveyor tread material, and cheap too!
Unread 20-12-2008, 01:57
lenny8's Avatar
lenny8 lenny8 is offline
Aww Yea
AKA: L-Deezy
FRC #1018 (Robodevils)
lenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud of
Re: Help!!..wheels?
When i went to AndyMark this off-season Andy said that he was new traction for his traction wheels ( to complement his new wheels ) so just talk to andy about alsohe said that his new treads should last 2 regional or even 3 .
Learn something, Know Something, Do something
Unread 20-12-2008, 02:08
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Help!!..wheels?
The colson wheels are great.
They actually have very good traction. Yes, conveyor belting has far more traction when it is new... but it doesn't stay new for long Remember wedge-top was designed for handling food.... I hope food isn't as dirty as the FIRST carpets... You'll need to keep replacing wedge-top or rough-top for it to stay fresh.
Colsons don't have this problem. They are designed for dirty environments like shop floors. And when they heat up from friction, they actually gain more traction.
They also wear very well. One set will last you a whole season. And when you're done, just throw the hole wheel away and get a new one! That’s how cheap they are!
I'll also throw support to the Colson wheels for three main reasons: durability, cost, and fabrication time necessary.
Durability: There are a lot of offseason competitions in the Northeast every year. Couple that onto the official scrimmage in February, and two official FRC competitions, and one of 228's robots can see eight to nine competitions a year. In New England.
The hard defense played up here really wears down Roughtop fast. We've been able to get an entire season out of a single application of Roughtop before, but after the first competition it already lost a considerable amount of traction. Colson wheels on the other hand (the 5"x2" Performa ones to be exact), went through eight competitions this past year without any noticeable change in performance.
Cost: At between $4 and $10, you will be hard pressed to find better wheels elsewhere for this cost.
Fabrication Time: About ten minutes per wheel, depending on how you do it. The approach 228 uses is to take aluminum rod, turn down the outside to a diameter slightly oversize past the diameter of Colson wheel hole, bore out the inside to axle diameter, knurl the outside of aluminum rod, use cutoff tool to cut off about 1-1.5" piece, use arbor press to broach hole with keyway, and then use arbor press to press aluminum rod insert into the Colson wheel. You now have a completed live-axle Colson wheel.
If dead axles is more your thing, then take one of the thinner 7/8" wide Colson wheels, put it on a rotary table, and drill three-six holes through the wheel, which you can then mount sprockets to.
Sure, they aren't as pretty necessarily as custom machined wheels, but at a final cost of about $10 a piece, ten minutes of machining time, and a sky-high reliability, they can't really be beat. And from an engineering perspective, that's beautiful.
Art Dutra IV
世上无难事,只怕有心人.
Unread 20-12-2008, 08:29
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: Help!!..wheels?
inlflateable wheels, dont wear down very easily......
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 20-12-2008, 09:31
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Re: Help!!..wheels?
We have also used Skyway wheels, which were part of the KOP in past years. We have doubled them for more traction, and applied belt material to them as well. You can order them with precision 7/8 OD bearings, 3/8 ID bores installed, which really makes them a good deal. I don't recommend the
.906 bearing option, as they are not very good quality.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 20-12-2008, 09:53
Re: Help!!..wheels?
Depends. 330 goes through a set of center wheels per event, roughly. They also drive the robot to its limits or until they get kicked off the practice field. (The practice robot? Double that.) Those are pneumatic casters.
The other year we used pneumatics was 2004, and we spent most of the time on the bar, so the wheels didn't get a lot of wear.
Unread 20-12-2008, 10:09
gorrilla's Avatar
AKA: adam spears
Re: Help!!..wheels?
we've only ever used them for 4wd....why would the middle wheels wear faster than the oustide one? it seems like the corner ones would have more scrubbing on the floor surface when turning
Adam Spears
Unread 20-12-2008, 10:12
Re: Help!!..wheels?
I never said the middle ones wear faster than the outside ones. Guess what else gets replaced at an average rate of once per event?
Unread 20-12-2008, 10:27
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Help!!..wheels?
We're looking at using 1/2" cantilevered dead axles again this year, and I notice that Colson wheels are available with a 1/2" bore bearing or bushing, although it's not the most common hole size for them. Instead of using a rotary table, maybe we could put a bearing into a sprocket, bolt it to the wheel with a 1/2" bolt, and use the holes in the sprocket as a template for drilling the holes in the wheel, bolt the sprocket to the wheel with the 3 or 6 small bolts, and then leave the bearing in the sprocket to keep the sprocket concentric with the axle on the robot.
There seem to be several different types of tread avaiable, do you have experience with some of the different ones, and recommendations?
Help with mecanum wheels CyDrive Programming 7 10-02-2008 16:16
need help about Mecanum Wheels mahmosh Technical Discussion 4 18-01-2008 11:50
Help with Omni wheels? atowle1236 Technical Discussion 35 15-01-2008 11:07
Help with Omni-wheels The GarbageMan Kit & Additional Hardware 12 10-04-2007 12:39
Sensitivity Wheels - help please naor52 Programming 6 20-01-2006 09:13
